Wondering what I might be up against before I turn any wrenches.
Figures I would spring a leak on my 1st time out with the new snowblower.
The weather cracked hose in need of replacement runs from the joystick block to the
block next to the hyd filter. Its a 95 L3300dt FWIW.
One end is a quick connect coupler and the other end connecting the joystick box
is threaded to a 90* fitting at the IN port., looks a bit rusty there.
Should i spray some WD 40 on it prior to trying to turn it off ?
Should I also change the line running parallel to it from the OUT port while I'm at it ?, probably same age but not leaking yet.
Will i lose any hyd fluid at the quick connect down lower by the filter when I disconnect that ? New to hydraulic hose replacement so trying to get off on the right foot.
