L2185 ~ 72" Front Snow Thrower, Mid PTO kit, and Sub-Frame (Complete, everything needed)
Larry M
L5030
Mar 4, 2021
Buchanan, Michigan
This 72"snow thrower has been lightly used and always stored inside, still looks about like new.
All manuals for set up and use. This is installed on a Kubota L5030 but will also fit some other models.
Package consists of L2183 Mid PTO drive kit, L2185 72" Snowblower, L2175B Chute kit, L2180-1 Quick hitch, L8313 Mid kit. asking $5000 for all. I believe this will fit on all L series tractors and maybe others, check with your dealer to see if it will work for you.
Located in Buchanan, MI zip code 49107 (southwest corner of Michigan)
I am able to load this for you or your transporter.
call or text 269-697-3520 if you are interested.
VikkiB
L3130. with L2185 snowblower
Dec 18, 2021
Hi Larry, Have you sold this yet? I'm just looking for the manuals for the L2185 Thanks Vikki
4,816
If you just are in need of manuals, your Kubota dealer can download the PDF and print them. If you bring a memory stick to the dealer, they can download the PDF to your memory stick, and you can print them out from there.
VikkiB
Dec 18, 2021
Thankyou!
TechMOGogy
B2910
Feb 27, 2022
Ontario, Canada
Assume Sold?
leveraddict
Apr 1, 2019
907
589
NEPA
His phone number is in the original post! Easy peeezy!
