Newcomer here,
I just bought this new-to-me B7100 HST. It's my first tractor so I'm new to just about everything. Went to finally move some gravel around for my driveway when it almost bogged down to shut off while picking up a bucket load. I was a little more careful on loading up the next bucket of gravel. I started to drive with the gravel in the bucket when it seemed like something was binding/bogging. So I dumped the load and noticed the front loader was a little bouncy and flexing like it shouldn't. (Yes, I had the throttle at an adequate speed. ) I pulled in into the shop to have a look and find that my frame is cracked.
I've already talked to a welder friend of mine who is going to try and touch it up, likely add some steel for support as well. I'll update this thread as I get some progress. I noticed on the other side it looks as if someone had previously welded in this same spot as well.
Does anyone have any experience with this issue? Why would it bog down and almost die? my thought was maybe under load the flexing made the driveline bind and cause issues? Curious what everyone's take is on this! My bucket has around a 500lbs limit so I know I wasn't putting too much on it.
