MX 6000….finally!
JRS
40
49
Central Texas
If it’s a disc harrow, yes it’s used to break up the ground and cut up vegetation (corn stalks, grass, etc.) just not as deep as a plow. Setting the angle of the axles on the disc gangs controls depth of cut. It also busts up plowed ground into a more level bed with smaller clumps. Hook a drag to the back and it makes a good seed bed. If you want a seed bed for a garden or food plot for deer a tiller may be great. If you want a seed bed for 50 acres, the OP has the thing to do it efficiently and effectively.
Back in the day spent many days running one after school until well after dark. Have an old one in the shed but haven’t had it out in probably 35 years. No use for it now.
I’d also like to see the MX running it if OP is up for posting some pics or a short video.
Yes it is an Armstrong HD 20/20 disc harrow. I will try to post pictures when I get a chance to use it. I have 17 acres currently to use it for food plots etc.
9,761
It's cool to see implements being used that many of us will probably never get to use. If that thing could pulverize partially submerged rocks I'd own one! Looking forward to photos of it behind your MX and seeing what it does to your ground.
