This engine (S2600A) has sleeves or as Kubota calls them "liners".
Thanks! Yep… I see the overhaul kits include liners…. Live and learn….(Learn not to believe everything the Kubota parts guy says.)
Now that I know it’s a sleeved engine… let me tell you about one that taught me a lesson about “knocking” sounds: I was given a Ford that ran poorly and discovered one cylinder which was very low on compression and had a Hell of a KNOCK…. (wonder if this might apply to your situation)…
I finally decided to tear it down and repair it before it threw a rod… so, I pulled the front axle from under it and blocked the frame up, dropped the sump …and found shards of steel laying in the bottom of the sump. Pulled the head and found cylinder number 1 had a shattered sleeve, most of which was in the sump! Yet that engine was running and producing enough power to run a 6-foot shredder…. but with a heck of a “knock”.
I ordered the overhaul kit and replaced all sleeves, pistons/rings, and conn-rod bearings….and didn’t touch the mains or the valves….and put it back together. Ran that tractor for 15 years mowing with a 6’ Rhino shredder as a “pull-behind” mower and definitely got my moneys’ worth!
Wouldn’t it be grand if you only have a cracked sleeve…err…I mean “liner”…and no other damage…??
