Is it not possible to drop the sump on a M4500DT to inspect the bottom end bearings, without removing the entire engine from the tractor?
Thanks rbargeron, and the photo is helpful. My other threads go in to detail of the problem.On Kubota tractors the oil pan is a structural part of the chassis so taking it off is a major teardown. And with the oil pan off only the con rod caps can be accessed . The mains are inside circular holders that all come out one end with the crank. (typical block pic attached) That said it is also true that bearing failures are pretty rare in Kubota Engines.
What symptoms does your M4500 engine have?
Not at hot idle, hot running (medium throttle). Very old tractor 1978-1980.With an engine of 2K hours or so….20psi at hot idle is NOT a problem oil pressure, IMO.
Not really, I will have to pay someone to come out. The problem is finding a mechanic who knows what he is doing from experience, than someone who things he knows and educated guessing.Might be helpful to have an experienced diesel mechanic (equipment and trucks) listen to it. If possible get more than one opinion. Can you trailer it ?
