L60 series rear Power Beyond
ACDII
Oct 21, 2021
678
421
Illinois
Now that I have the B2410 PB for a log splitter in the rear, I am wondering if the L60 has a similar setup in the rear. I have an L4060 on order, tractor is in, waiting on loader and rear remote kits, and now that I can split logs with te B2410, I want to have the same option with the bigger tractor.
I watched a 3rd function kit get installed on a B2601, it included lines for the backhoe, IE Power Beyond, for the rear and wonder if the 3rd function kit for the L4060 would have the same. I am going to add that along with the quick attach remotes once I get the tractor, though 6 month wait time on those.
eipo
L4060
Dec 1, 2015
693
MI
If you're adding rear remotes to the 4060, you wont need to worry about PB. Just use the remotes.
Also, make sure they are getting you the updated linkage if you're adding 3 remotes.
eipo
L4060
Dec 1, 2015
693
MI
Hard to explain, when I get out to the garage, Ill get you the part number for the updated linkage. I never actually installed it because my modified linkage has been working just fine.
ACDII
Oct 21, 2021
678
421
Illinois
Well considering it will be a new kit, chances are it will be the latest version. If I can get away from having to bungy a remote, I would prefer that route. I would also have to replace the fitting on the log splitter in order to switch between them since It has one male and one female on it.
eipo
L4060
Dec 1, 2015
693
MI
Mine was a new kit, too.
Good point on the valve, hadn't thought about that.
eipo
L4060
Dec 1, 2015
693
MI
What is the updated linkage and what does it resolve or improve? Thanks.
In this picture....
You see the front horizontal bar with round bar tacked on.. Thats the bar that goes to valve 1. Directly behind the vertical round linkage that mostly in focus, you can make out the vertical flat linkage that goes up to the handle. This linkage obviously isnt lined up with the horizontal linkage. It needs an offset in it to mate up. The updated part has the offset built into it.
