Do you have a BX23S with the Curtis Deluxe cab? Today I removed my backhoe in preparation for the installation of the weight box for the winter. Everything went well until it came time to put the hose that comes off the left side of the tractor onto the female connection on the right-hand side of the tractor. I just couldn't plug it into the other half of the coupling. I then looked at the part that I took off of that fitting and noticed that it has a 90 degree fitting at the male coupling where it joins the hose. I tried it in the coupling and had no difficulty installing the male coupling into the female coupling. Upon very careful examination, I realized that the metal of the hose was hitting on the edge of the tractor cab. I dug around in my box of hydraulic fittings and found a suitable 90-degree fitting to remedy this issue. I would have thought that the dealer would have seen this as being an issue and resolved it prior to the delivery of the tractor with the cab. Does your tractor have this issue or did your dealer make the necessary modifications to the hose? I will post some pictures in the morning. It was cold, and I just left this to finish it in the morning when there is more light and it is warmer.
