Taking the Loader off a BX23S question
2020 BX23S, Threatened and Intimidated into silence.
5,150
I was wondering if I could take the loader off of my BX23S with the bucket removed. I am planning on using the quick attach for the snowplow if the snow is just a thin coating, and using my front-mounted snowblower for the heavier snowfalls. I have only had the front loader off once, and I had a difficult time getting it off and back on. I would read the manual, however, it was liberated at some time in the past, prior to my purchasing the tractor.
Crash277
BX23S
Jan 17, 2021
844
621
Not sure how you would be able to do it without the bucket as you need to use the curl function on the bucket to lift the arms out of the locks.
imnukensc
BX2380
Sep 10, 2015
698
605
Midlands of SC
Plenty of youtube videos of how to remove and reinstall the loader on a BX23S (or 2380) since they're the same loader.
bird dogger
Vendor Member
Feb 24, 2019
1,656
1,554
North Dakota
For my older JD750 I had a designated spot inside my shed for removing and storing my loader when not in use. It involved a rope and pulley system connected to a hand winch (think boat trailer winch) mounted nearby. I didn't have to monkey with any stands or special procedures. Drive into the spot. Hook up the two lifting points to the loader posts. Unpin the loader and crank the loader arms up.
I may do the same with the kubota loader. It wouldn't matter what was on the loader's ssqa or if nothing was on it. But you do need to keep access to that loader spot open.
