Grill Guard - Simple & Cheap?
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
Hi Folks,
I run a L3130
I added a grapple to my set up a few months past ( love it ). So far, I've used it without the mesh component on my Grill Guard. I know I'm living on borrowed time before I run something through the tractor grill.
I've looked at all the threads of custom builds and I'm impressed. Unfortunately, I'm not currently set up for self fabrication. I have found an aftermarket retailer who is at $350 plus tax/shipping. That's a little steep for this problem if I can avoid it.
Has anyone come up with a solution which not a total custom fab job that works? Beauty over function is not a priority at this time.
Thanks
My current grill guard looks like this:
Fladogman
116
87
Crawfordville Fl
Can you weld? If so expanded metal is cheap and works pretty good. The guy at the metal shop gave me the metal from his scrap pile for mine. I'm also planning on adding barrier to the back of my grapple for added protection. I had a limb come through the back and lift my ssqh lever once.
Reactions: 6 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,704
2,144
Western MT
I bought a heavy metal guard.
If you don’t weld, I think you could bend some expanded metal to fit around the bars after cutting, paint it, and then drill and bolt through the guard uprights running the bolts through the holes in the expanded metal.
Bmyers
May 27, 2019
3,508
4,472
Southern Illinois
I used expanded metal on mine. I would like one of the nicer ones and several i have looked like appear to offer better protection, yet so far, this one has worked great and the price was right (cost of the expanded metal which was pre-covid).
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
Thanks All.
Expanded metal is new ( I never knew what it was called ) to me but I see the utility.
9,905
Thanks All.
I prefer perforated steel over expanded steel for this application but it's not as cheap. It can be easier to work with in terms of welding, and it's certainly stronger. Expanded steel is typically chosen for applications where overall weight is an important design concern and where the strength of perforated steel isn't necessary.
I have all the material I need to make a guard for my MX but I've decided to wait until the new tractor shows up rather than weld up something that I won't get to use.
jimh406
Jan 29, 2021
2,704
2,144
Western MT
Buy some expanded metal; larger than the front face (add a couple inches for each side). Hammer it over the edge and use some self-tapping screws with washers on the sides to fasten it.
I don’t know if you’ve tried drilling the sides, but they aren’t very soft. I don’t think you will be very successful with just self-tapping screws of large enough size to hold the expanded metal on impact.
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
egilchrest
Kubota L3901
Sep 16, 2021
11
39
Oxford, CT USA
I got some stainless perforated sheet and some stainless bar and welded something up over the weekend. Seems like it will do the job. I liked that it was mostly open so it doesn't interfere with the lights. And stainless so I am not dealing with a lot of rusting down the road. f3741cdb-35c7-4548-884b-741eb29adb27.jpg
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
41
KY
I went with the perforated sheet as well.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
LarryBud you are on the right track improving your grill guard. If you can take the grill guard off and take it to a high school vocational or weld shop can get
some expanded metal on cheap. You paint and your back in business.
Gravel screen, 3x6” tube bumper, hooks and ring. Factory bonnet guard.
