V Vmitch09 New member Equipment L3301 Nov 9, 2021 2 1 3 Gulfport Ms Nov 9, 2021 #1 It seems that the lift lever is not engaging the valve in the up and down modes. Side to side is working but the lever just falls down.
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 8,742 4,481 113 Myersville, MD windyridgefarm.us Nov 9, 2021 #2 Vmitch09 said: It seems that the lift lever is not engaging the valve in the up and down modes. Side to side is working but the lever just falls down. Click to expand... Assuming this is an LA525 loader take the plastic cover off and inspect the joystick linkage. Dan Last edited: Nov 9, 2021 Reactions: 1 users
V Vmitch09 New member Equipment L3301 Nov 9, 2021 2 1 3 Gulfport Ms Nov 9, 2021 #3 TheOldHokie said: Assuming this is an LA525 loader take the plastic cover off and inspect the joystick linkage. Dan View attachment 69393 Click to expand... I just did and the bolt on #70 had worked out, problem fixed, thanks Reactions: 1 user
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 8,742 4,481 113 Myersville, MD windyridgefarm.us Nov 9, 2021 #4 You are quite welcome and glad it was simple. Dan
