5,170
With the monsoon wind and rains the last couple days there is no outside tractor time. So Last night I got a head start on the 400hr service. I did the engine oil / filter change - otherwise known as oiling the garage floor. I don't know why but every time I do an oil change on any vehicle I manage to spill at least a little oil on the floor.
I use a 12V dipstick pump.
Works great, but rather slow.
No spills though.
PaulL
2,566
1,527
NZ
Replaced the dynamo on my B2601 with an alternator. 14v at idle now. Took about 90 minutes, only because the new belt was slightly too short to slide over the alternator pulley when adjusted all the way in, so had to angle the alternator behind the belt then mount it. Then find the top bracket was a little off, so loosen that to get it to mount smoothly, then take the alternator off again to tighten it because the alternator was in the way, then angle it again and put it on again. And finding the regulator under the dash to disconnect was harder than you'd think.
Overall very happy. I run an electric sprayer on the 3ph, an electric fertiliser spreader on the 3ph, and an electric transfer pump on my diesel tank (for getting heating oil into the house tank). The dynamo didn't really charge the battery up unless you did a good run at full revs, so some days it was pretty lazy to start.
millsrv
L2501 HST, LA525, BH77, Gannon Rollover Scraper, Titan Skid Steer Attach Forks
Nov 20, 2015
69
Placerville, CA
Carrying a chain saw on my tractor has always been a pain. Putting an expensive saw in the backhoe bucket is not a good plan. Recently I found this ATV chainsaw holder on Amazon for under $70 and decided to order it. I did make modifications to the mounting bracket using a band saw but other than that it was a simple install. I usually have pallet forks on when doing tree work so the loader bucket is not there to carry equipment. I think this might be a reasonable to carry and protect my saws.
MOOTS
MX6000
Jun 27, 2019
2,153
2,649
Canton, Georgia
Very nice. Would love your honest opinion on the Stihl battery line.
S-G-R
LX3310 for now, L5460 in progress
Jun 17, 2020
1,333
3,058
PEI Canada
Update in my FDR2584 mower. Cliffs notes: Mower delivered on a Wednesday and the belt disintegrated after 40 minutes of use with no warning.
The dealer picked it up and took it back for repair and found that the bolt for the spring tensioner had a lot of paint in the hole causing it to stick. He took the bolt out and removed the paint, greased the hole and reinstalled the bolt. Mowed 4.5 acres without any problems.
The bolt is under the gearbox
I picked up the deck and was pleasantly surprised to see minimal grass buildup considering the grass was quite long and not as dry as it would normally be when I mow.
Rzims
B7800
Apr 28, 2021
20
California
Nice setup - I bought the battery stihl MSA 160 this year and really love this thing. Bought an extra battery and I usually run out of steam before it does....
Crash277
BX23S
Jan 17, 2021
844
621
Went to the farm and moved some trailers. Stored the wife’s 2 horse bar conversion trailer there. Not enough room to use a truck so the little BX for the win today!
6,846
As much as I dread the thought, seasonal conversion done.
“Ran the chains in”. All good there.
Did have a little hydraulic fluid leak. Looks like a coupler. Unhooked and re-connected. Think it’s good now.
PM7788
LX3310HSDC, LA535 FEL, LX2963 Snowblower
Aug 28, 2021
MA
Well. Haven't been on in a few days due to the massive storm that hit Massachusetts. Almost lost my brand new tractor. Tree fell to the left and missed it and another to the right that landed on my truck. The Kubota gods were good to me, the Ram gods not so much. Spent the past few days cleaning up the mess and spending as much time as possible on the LX3310.
Reactions: 6 users
RichardAaronlx2610
Aug 3, 2021
451
505
New Jersey
Well. Haven't been on in a few days due to the massive storm that hit Massachusetts. Almost lost my brand new tractor. Tree fell to the left and missed it and another to the right that landed on my truck. The Kubota gods were good to me, the Ram gods not so much. Spent the past few days cleaning up the mess and spending as much time as possible on the LX3310. View attachment 68899 View attachment 68900 View attachment 68901 View attachment 68902
Wow you got super lucky man! That tree would have hurt! How bad did the ram get it?
PM7788
Aug 28, 2021
MA
The truck got hit pretty hard. big limb, larger than the one in the pictures above landed on the roof. Smashed it in pretty good. Have to see what insurance says and if it's a total loss or not. Looks like it might be.
I'll never get rid of my KTAC insurance, thats for sure :LOL:
RichardAaronlx2610
Aug 3, 2021
451
505
New Jersey
you surely got lucky that’s for sure! I took A major loss to a bad storm back in 2010. I feel your pain man!
PaulL
2,566
1,527
NZ
Did you buy a Kubota kit or select your own parts?
Bought the kit. Really glad I did. Everything fit exactly like expected. The instructions were incredibly brief. They were correct, but really could have done with a bit more step by step. I found a YouTube video that was very helpful.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
553
NH/VT NEK
With winter coming and the hour meter sitting at 47.x hours I took the opportunity of a rainy Saturday to to pull the B2601 into the garage and do the 50hr service a touch early.
Overall everything went smoothly......I ran into the common issue of the two drain bolts being heavily covered with the engine block over spray which wouldn't allow the socket to slide on. Once I finally got them off I cleaned them up to prevent that issue next time.
Filters were easy to get off and fairly easy to work on which is nice. Fired it up, dropped the bucket and grabbed the pallet fork frame and hitch and moved the horse trailer, swapped the bucket back on and setup my sand barrels along the driveway for the next 5 months of snow and ice. I also swapped out the box blade for the rear blade.
I think the blower will go on before Thanksgiving........or maybe over that holiday.
PM7788 that was a heck of a storm.......my inlaws in Warham jsut got power back on Saturday
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Well I narrowed my buds kubota u45 andtook the scrub brush off a section behind barn, stripped topsoil off. Time for stone and gravel for the extension. Hopefully mother nature holds winter off a bit longer, also installed new driveway gate, and put some ditching in behind barn and in pasture. Had a lot of rain so was pretty sloppy but gotta do what ya gotta do. Now on to finish putting firewood in shed, and getting the piles of lumber the amish milled up into a building lol winter can wait ...
8,792
In addition to moving trailers around and clearing up in preparation for winter, I've wanted to move a big boulder ever since I bought this place and finally got it to a better location yesterday. It was one heavy and awkward beast and I gave myself a Halloween scare yesterday afternoon as I came down the asphalt driveway with the rock in the jaws of the EA grapple. I started to slide (yaw) and began to wonder if this was it. You can see the skid marks on the asphalt in the photo below. The R4 tires have no traction on the asphalt and the smart move would have been to drop the grapple and boulder to the ground but I hung on in there and got the tractor back under control where the driveway levels off a bit.
I placed the rock in front of the sign I made about three years ago. I'm going to add a few more smaller rocks at some point but I'm glad that's over. The EA box blade weighs around 800lb and the rock must be twice that and it was too much. I have to say, I'm less than impressed with the traction from these R4 tires on my property, whether it's on dirt, grass or asphalt. The rear tires seem to break loose at the drop of a hat and end up digging up the grass and then the dirt. I guess the MX isn't lacking for torque.
I hope I didn't do any damage to the driveline as I was sliding down the driveway.
Reactions: 11 users
B737
LX3310
Jun 9, 2019
2,022
2,204
lol that is awesome ^^^ and I totally know the feeling of the code brown :poop:!
Reactions: 6 users
