9,611
WOW!! Beautiful 10 (?) point. What, maybe 20-22" spread? Definitely in the rut, big time. Look at the neck...
Betting pretty heavy dressed weight....looks stout.
You didn't field dress him?
Where you're at, what do you have for ungulate games species; obviously whitetail, elk (?), moose (?), blacktail (?), pronghorn(?).
Thanks and yes, a 5x5 as they say up here. Spread is only about 17" widest point to widest point. I gutted him last night and hung him up with the FEL. I finished up today skinning, quartering and getting the head ready for the taxidermist. I'm hanging the meat for a few days before processing so have it in game bags in the garage. I wish it were cooler but it's down in the low 30s at night.
We have elk, white-tail, mule deer, sheep and moose up here. The antelope are on the other side of the Rocky Mountain Front. I shot an elk on my property last year and might get another chance this year if it gets colder.
Reactions: 6 users
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
195
139
Villa Rica, GA
Picked up an old fertilizer sprayer frame. Will fix it up and make it a sprayer again or possibly cut it down into a platform for landscaping items. All the plastic bits will be replaced. Just needed the frame.
old and tired
L2800 HST; 2005; R4
Mowed some cotton plants... it rained a wee bit today so we could not harvest as planned. It's one of our regulated cotton trail that is crop destruct. This was some border cotton surrounding our test... We'll harvest in the next day or two, then dump it all on the ground and burn it.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Decided I really needed a shackle on the drawbar. After I received it today I wasn't happy with the pin:
I like to install any pins like this with the retainer on top. That extra T handle hanging below the drawbar in the woods wasn't appealing. So
The grinding wheel made short work of it.
5,245
Not a criticism, just a question: why do you install with the hairpin on top?
I’ve always installed with the hairpin on the bottom as the linchpin doesn’t automatically fall out of the hairpin is dislodged, or maybe it’s just out of illogical habit.
Magicman
Oct 8, 2019
6,057
9,528
Brookhaven, MS
knotholesawmill.com
In this instance I agree with the hairpin being up to prevent debris from unlatching/loosing it but, that appears to be the wrong size hairpin. Much too small.
BigG
Sep 14, 2018
1,951
774
West Central,FL
I would never place a hitch pin in upside down. If you are worried about the hairpin getting caught simply push it onto the hitch pin until the hitch pin is in the hole where you would place your finger when pulling the hairpin out. That way the hitch pin stays in place if you did lose the hairpin.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Well I appreciate the comments about the orientation of the pin. Over the years I have lost a couple of low hanging hairpins that were disengaged by who knows what in the woods. I have never lost a pin where the hairpin was 'upside down'.
I agree with Magicman the supplied hairpin is too small. I'll definately change that. I prefer these safety spring pins - Have never had an issue with them.
BAP
Dec 31, 2012
3,033
1,149
Push the hair pin in all the way to the loop and it won’t get dislodged.
RichardAaronlx2610
Aug 3, 2021
451
507
New Jersey
It fits with the new back blade on….just barely. Left the shop stool and crate there to avoid shin-scrapes…I hope.
Blower isn’t hooked to PTO yet. Chains not on the rears yet either.
Got the towering pile of pellets behind it. That stack is done by mid-January or so.
How long does a bag of pellets last you? And is that your only source of heat?
litework
Kubota LX 3310 HSDC, LA 535, RCR1860, SGC0660, BB1254, FDR1660
Aug 12, 2021
17
27
Removed three stumps from the yard over the weekend. I couldn't get all of the one in the picture. I'll need to grind it below the ground. The roots are very large and too close to the road for comfort.
7,075
On average, I burn about 1.25 bags/day - - only heat source, but do have oil-fired boiler for backup.
Equates to about $6.50/day for heat with pellets.
I figure fuel oil averages about 3+ gal/day. I think $1.80/gal oil is about break-even. Running ~$3.25 last I checked.
5,937
Same here. when its really cold I can go thru almost 2 bags/day heating 2600 sq ft. The pellet stove does the heavy lifting, ductless heat pumps just don't provide that radiant heat to make you feel warm so, they run as backup. I also have a propane fired boiler that I've only used once.
RCW, those look like TSC pellet bags. I picked up a ton locally from TSC but they were the nasty hardwood pellet blend. I didn't have a choice since my preferred provider can't get hardwood pellets this year.
7,075
Same here. when its really cold I can go thru almost 2 bags/day heating 3100 sq ft. The pellet stove does the heavy lifting, ductless heat pumps just don't provide that radiant heat to make you feel warm so, they run as backup. I also have a propane fired boiler that I've only used once.
Very nice spot you have there.
Yes - - those are the TSC 100% Hardwood. Used them last couple years.
Had to go to another TSC to get these. My stove hasn't balked at any brand/formulation thus far, but know these have been okay.
Hope I'm stocked into March/April....
RichardAaronlx2610
Aug 3, 2021
451
507
New Jersey
Very cool man, that’s not too bad at all. I have a wood stove waiting to go in my house. I’m tired of paying the gas company every month lol
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
With the monsoon wind and rains the last couple days there is no outside tractor time. So Last night I got a head start on the 400hr service. I did the engine oil / filter change - otherwise known as oiling the garage floor. I don't know why but every time I do an oil change on any vehicle I manage to spill at least a little oil on the floor.
Oliver
L2501, JD 3520
Feb 2, 2011
540
129
Preston County, WV
......I did the engine oil / filter change - otherwise known as oiling the garage floor. I don't know why but every time I do an oil change on any vehicle I manage to spill at least a little oil on the floor.
LOL sounds familiar. What I do now is lay a large cardboard panel on the floor for the drain pan to sit on to catch and absorb any splash and spills. I cut or unfold the cardboard panels from large boxes and store them behind a shelf usually reusing the same one a number of times. Once saturated I cut it into strips for fire starter.
RichardAaronlx2610
Aug 3, 2021
451
507
New Jersey
Split firewood with the hoe, 😂 and broke the bead on some aluminum wheels. 30 more to go.
5,245
