Just joined this forum and this is my first post.
I purchased my 7060 early this year used with < 100hrs. It's a 2019 model. I also bought a new Bush Hog 316 and this is mostly how I have used the tractor. Recently I purchased a new 8" disc and the 3 point hitch issue is more of an aggravation with the disc which I raise and lower more frequently. So here is what I'm experiencing:
The 3 point hitch raises very well, but it will not let the implement down (usually) without first exercising the draft control lever. I keep the draft control all the way forward (float position) except when I'm lowering the 3 pt hitch. To lower the implement, I first lower the 3pt lever position (implement stays up), then I move the draft control lever about an inch back and then return to full forward. Then the hitch will lower. I can't believe it's supposed to operate this way, but I see nothing in the manual that sheds any light. Needless to say, this gets old when you are frequently raising and lowering an implement. The hydraulics are very strong on 3 pt and also on loader. The speed control knob has no bearing on this unless it is closed completely and then the implement stays up no matter what else is done. I've tried moving the speed control knob back and forth with the implement raised and position control lever in low position (without touching the draft control) and nothing happens.
I retired late last year after 40+ years and bought some land and some equipment. I grew up on a farm, but in those days there was no draft control on the 3 point hitches that I recall. Is this an operator problem because I'm doing something wrong? I will appreciate any insights the forum members may have to offer.
