Anyone pulling their mx6000 with loader and hog or comparable setup, on a 3500 lb duel axle trailer… got the trailer but been told need to upgrade to 5000 lb axles to be legal…. Thoughts on the safeness of using the 7000 lb trailer
Surely someone will come along soon, to state that trailers over 10,000 lbs. GVW cannot be towed without a CDL.If your tractor is an open station ROPS without tire ballast then you are probably looking at about 6,000 lbs with loader and hog. With tire ballast you will be more like 7,200 or so. I'm guessing that you will need a 24' long deck to load that with correct tongue weight. Those trailers are at least 3,000 lbs empty and can easily get past 4,000 for the heavy duty ones. I'm looking at trailers myself and will probably end up with a 12K or 14K because as you can see a 10K one might not be enough.
I am of the opinion that this limitation ONLY applies to trailers towed for commercial use!
I use my personal use 15K registered equipment trailer for my personal use Kubota L48 TLB. (2-7,000K axles, 1,000 ton tongue)
The L48 weight is 8,000 lbs, and trailer weight is 3,500 lbs.
Is this legal?
I think so!
That is right. Although Georgia is stopping on secondary roads, they are very active on the interstates. If you are towing anything (except a small trailer under 14’ ) with a 3/4 ton truck or above, you will likely be stopped and get a full inspection.After looking it up I remember now that there is a federal law requiring a class A CDL for trailers over 10K lbs IF your total combined gross vehicle weight rating is over 26K lbs. I should check all my axle weights and such on my truck before buying a trailer. It is 10K GVW but that is only part of the story.
Aside from the Federal referenced by others, state laws vary quite a bit. For instance, NC differentiates between “property hauling” vehicles and recreational vehicles. So in NC I can tow my 9,000lb camper legally with a 6,000lb (adding a bit for fuel and passengers) pickup with a standard Class C driver license and a standard license plate. I could also tow a boat (if I had one) on the standard tag. However, if I’m towing my little 5x8 enclosed trailer that makes it a “property hauling” vehicle and my driver license is still OK but my gross combined weight is limited to 4,000lb by the tag on the truck. The truck weighs more than that so the only way to make it legal if I’m stopped is to leave the trailer on the side of the road at which point the pickup is no longer a “property hauling” vehicle. Makes little sense but that’s the law here. Commercial v personal use makes no difference.I think each state is a little different but I believe you are correct about it being for commercial use. In Ohio you don't need a CDL for a 30,000 lb RV with air brakes so trailers probably fall under the same "personal use" rule.
That works for me!That is right. Although Georgia is stopping on secondary roads, they are very active on the interstates. If you are towing anything (except a small trailer under 14’ ) with a 3/4 ton truck or above, you will likely be stopped and get a full inspection.
Not me! I tow my MX6000 with the FEL and Land Pride RCR1884 attached on a 22ft 14,000lb rated trailer. Next year my plan is to back the tractor onto the trailer and rest the loader on the raised ramps, or make up something to rest the loader on. I added a Curt weight distribution hitch set up to the truck and trailer after towing the MX to my friend's place.Anyone pulling their mx6000 with loader and hog or comparable setup, on a 3500 lb duel axle trailer… got the trailer but been told need to upgrade to 5000 lb axles to be legal…. Thoughts on the safeness of using the 7000 lb trailer
A weight distribution hitch (my Equal-i-zer brand) makes a huge difference in towing safety!Not me! I tow my MX6000 with the FEL and Land Pride RCR1884 attached on a 22ft 14,000lb rated trailer. Next year my plan is to back the tractor onto the trailer and rest the loader on the raised ramps, or make up something to rest the loader on. I added a Curt weight distribution hitch set up to the truck and trailer after towing the MX to my friend's place.
I don't think you'd have enough capacity to put your set up on a trailer rated for 7,000lb when you include the weight of the trailer.
Yeah. It’s a bad feeling to see the blue lights come up behind you and realize it’s the DOT Enforcement SUV. You know you are going to be there for a while for an inspection if the trailer doesn’t have an inspection sticker on it.That works for me!
I have no plans to tow anything to, from, or within, GA.
I believe that trailer "inspection" stickers are not required in most states.Yeah. It’s a bad feeling to see the blue lights come up behind you and realize it’s the DOT Enforcement SUV. You know you are going to be there for a while for an inspection if the trailer doesn’t have an inspection sticker on it.
With my last truck, they even checked the fill neck for signs of red dye to see if I was using non taxed (farm) fuel. They were going to try to pull a sample but the Ram trucks have the block in the neck to prevent fuel siphoning by thieves.
