most people buy the MX instead, unless they specifically need a smaller/lighter tractor with a lot of HP - and 47HP is a lot in that frame size.
That’s a succinct and accurate statement of the niche that the L4701 fits and how it differs from the MX. If the need is for more HP, specifically PTO HP, than the frame size would typically indicate due to weight being somewhat of a negative for the intended use, it’s a good fit and that’s a legitimate comparison to the next size up MX which has nominally more HP and significantly more weight. For drawbar and loader capacity, which both require weight, the MX is clearly more capable. For mowing, running PTO implements such as chipper and generator, where weight is either a non-issue or a negative, the L has some advantage in both cost and less weight.
For example if I was still pulling moldboard plows, while the L will pull a plow, it doesn’t have the weight to pull what the 47hp rating might lead one to believe so some of that 47hp is not fully utilized and therefore it wouldn’t be a good fit for that purpose, and certainly not with R4 tires. The MX would also be a much better choice for stacking round bales. However, the L4701 with R4’s causes much less damage to our numerous and steep dirt trails than our lighter 2wd R1 equipped tractors. I would expect an even heavier MX would cause more damage than the L. To rock the trails into real roads, at the time I costed materials a couple years ago prior to purchasing a new tractor, would have run around $50k just for the rock, and would have been a major project with some of them being as much as a half mile from dump truck access, so that’s not happening while there are alternatives such as running lighter 4wd equipment. However, the smaller L’s didn’t have the PTO HP to run a chipper sufficient for our needs. And I do agree, the higher HP to weight ratio of the L4701 makes it a reasonable choice for users such as golf courses and some commercial landscapers that have a need to run large finish mowers with minimal soil compaction. That doesn’t mean that’s the only scenario where a lighter higher HP machine is desirable. Not a good solution for every user, but no model is, which is why there is such a plethora of models.
That sort of true comparison is potentially useful for someone considering a L4701 v a MX5400, which seems to be a common comparison. Particularly for those new to tractors they may be fixated on HP and not considering the advantages and disadvantages of weight for their uses.
How many “sister” models are in a machine’s class isn’t useful information to determining what is a good fit for the buyer. It’s a machine, not a family. “Skip the orphan” without any explanation of why doesn’t educate the buyer on what the differences are such that they can make a more considered decision on what best fits their needs.
An explanation of weight, HP, loader capacity, and tire choices impact on the various areas of performance so a buyer can make a good decision on what best meets their needs IS useful.
It’s about like me telling someone asking about a B v a L to skip the B for a “real” tractor with no explanation of why I think the L is a better fit for their intended use. It’s just useless to them and ignores the fact that the B is a better fit for some purposes.
