Garden bedder QH20 compatibility
GrumpyFarmer
4,000
Good day. Does anyone have a garden bedder / hiller that is compatible with QH20? If so what make and model of garden bedder. Any suggestion would be appreciated. Thanks.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
I have the Land pride QH 20 on my L4600, I use the Everything Attachments garden bedder with it. Works great no issues.
Been using it for about 5 years now with it. I do just pick up the bedder and sit it on the QH, the lock it down and off I go.
I have the GB60.
When making my rows I place a piece of 3" pine across the spring tines to level off tops of rows. I use 2 ty wraps on each side to hold it in place, once rows are done then I remove it so I can hill my rows at the plants grow.
Best of luck and be glad to answer any specific questions you may have.
GrumpyFarmer
4,000
I have the GB60.
Thank you.
GrumpyFarmer
4,000
Thank you.
Couple more questions….did you have to switch out to wider lower link pins for for the qh20 to work? EA replied to email they sent and said it only fits Cat1 hitch? However QH 20 is maybe wider than the qh10 or qh15 which are cat 1. Did yours fit just as purchased to the larger QH?
Creature Meadow
Sep 19, 2016
1,065
140
I am sorry for misleading you, mine is the QH15! For some reason I thought it was the 20 but I checked it over the weekend when using my land plane and saw I was wrong.
I apologize for providing the wrong information.
I'm still happy to help any with the bedder but cannot help regarding the QH20.
Thank you.
Jay
GrumpyFarmer
4,000
Thanks for checking further. I sent EA a second email based on your initial response….I also included the blueprint / dimensions of the QH. From their explanation sounds like the lower pins are about 31 inches. The QH20 needs 40. Sounds like only cat 1 from EA product offerings. Thanks. Have a safe day.
