Hi
I'm trying to resurrect a Kubota d1105 engine that's been sat idle in my barn for about 10 years. I'm a bit of a novice when it comes to engines so I thought I would dive straight in and use it to teach myself some new skills.
However, I'm having trouble getting it to start and have tried just about everything including;
1) new fuel and filter
2) verified the glow plugs are working.
3) checked the fuel cut off solenoid is ok
4) removed the air from the injector lines.
5) compression checked each cylinder (about 400psi)
After scratching my head for a few days I removed the injectors but kept them still attached to the rail to double check they were spraying fuel, and was surprised to see absolutely nothing. Not one drop of fuel coming out of the injectors. Thinking there may be an air lock I loosened up the injector pipe connectors (at the injector end) and fuel spurts out of each when I crank the engine. But nothing out of the injectors when I tighten them up again.
I'm a bit stuck. Could all injectors be faulty ? (seems unlikely they've all failed) or do I have a problem with the injection pump despite it clearly delivering fuel to the top of the injector?
I did remove the injector pump and it looks ok with the three spring rollers are looking like they should.
Any advice?
Any advice?
