BX 25 Hazard Light Lens
yzinger
71
Nova Scotia, Canada
hey folks. So I am told that the hazard lens for our BX25s have two different part #s. I cannot find a difference when looking at them on the tractor and I believe you can remove a lens and place it anywhere else without issue. (example remove left back and place on left front or front or back of right)
I knocked one of when bush hogging and exploded it lol so I know need a new one but I dont know which to order as they both fell off but only one got trashed.
Does anyone know the difference between K2581-62630 and K2581-62640??
bluedunn
BX1860, FEL, MMM, Heavy Hitch Back Plow Blade
Aug 29, 2019
304
40
Thetford, VT
Definitely a mystery when I search the internets - maybe call/email your deals and ask?
Taking a look at Messick's, I can see both 50 (Lens 1) and 60 (Lens 2) referenced in the diagram...the Job Quantity for both says 2, so maybe either one will work:
yzinger
71
Nova Scotia, Canada
Dealer says this:
So there is a slight difference between 41 & 42, one tiny little notch. We have both in stock and they are the same price. All you need to know is if you are sitting in the tractor seat, is the broken lens on the left or right and is it the front half or back half of the light.
But, as noted both fell off and only one broke so I dont know which one i put on. Im pretty sure I can install the lens anywhere but was hoping OTT had some views.
BXHoosier
BX24
Jan 21, 2018
509
626
Indiana
To help prevent the lenses from popping off again, run a couple zip ties around them. 3D6092CB-8AA1-40D6-9D0A-46192DFBA00F.jpeg
yzinger
71
Nova Scotia, Canada
thanks all. I got the new lens on the weekend. It is indeed 2 different part numbers. The difference is where they clip together on the inside near the ROPS. I will try to get a picture if anyone wants one. Each lens has a small notch so it can cuddle around the tab so to speak.
