That is "normal" after filter changes at 50, 200, 400 and 600 hours ?That is what we usually see that at the first or second suction filter change. That is normal machining debris, nothing to worry about.
Go back and read the first post.That is "normal" after filter changes at 50, 200, 400 and 600 hours ?
Re-reading the first post provides absolutely no additional information about what is "normal" after a 600 hour filter change, with 3 previous filter changes!Go back and read the first post.
The " I have changed the filter at 50, 200, 400 and now 600 hours and have never seen metal shavings like this " did not sink in?Re-reading the first post provides absolutely no additional information about what is "normal" after a 600 hour filter change, with 3 previous filter changes!
The debris on the magnet is from the manufacturing, machining, and break-in of the trans-axle assembly. It has just now been sucked up to the filter. It has just now gotten to the suction tube and been sucked up to the filter as it's been in there the whole time. Most of the time, it happens in the first couple hundred hours, some later. It is nothing to be concerned about. In 200 hours when he replaces his filter again, there will be very little debris.
I service over 100 L, M, and MX series tractors a year, this is not uncommon.
Thank you WhiteTiger, you saved me from trading it off.The " I have changed the filter at 50, 200, 400 and now 600 hours and have never seen metal shavings like this " did not sink in?
