RTA1266 PTO conical dog bolt
scratchnsniff
2021 L3901HST
Aug 10, 2021
NE Ohio
My tiller showed up Friday. I took some time to get it set up for my QH, checked the oil, and took it out back. Dealer cut the PTO shaft before delivery and based on the manual it looked OK.
After an hour or so I heard a bang and looked back to see the PTO shaft flopping around still attached to the tractor. The conical dog bolt, on the end with the nut, bent and snapped off.
I vaguely recall the tiller hopping a bit at that time. I was moving very slowly. Based on how the shafts go together at the tiller I was very surprised this bolt broke.
I’ve ordered 2 so I have a spare on-hand. Is this a common part to break?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,439
1,733
Kalamazoo, MI
I trim my PTO shafts to a length such that I can decouple the shaft from the tractor at any point of the 3PH travel. Did you double check the dealers work?
That conical bolt goes into the locking groove on the splined input shaft. The only way I can figure it breaking would be due to axial movement of the yoke on the gearbox input shaft. Even so, it would be rolled or mashed.
5,845
Sounds like the tiller found a rock, got jammed, broke the shear pin. Happened to me every spring for 11 years, until house got built there. I keep a toolbox on the tiller with 3-4 'kits' of parts and tools .
scratchnsniff
2021 L3901HST
Aug 10, 2021
NE Ohio
The PTO shaft length is OK based on the setup laid out in the manual - no issue there that I can see.
The bolt just locks the slip clutch end to the implement. According to Land Pride it's not a shear pin like some other implements have. The person I spoke to said he's only ever heard of a handful of these breaking.
This is the carrier dog bolt from the parts manual - #5
Compared to the shear bolt for my rotary cutter (which hasn't come in yet) shown as #18.
LP agreed to ship me a replacement and requested I return the piece(s) I could find of the original for their QC department to check out.
It's solved, I guess, for now.
JimmyJazz
1,270
805
Pittsburgh, Pa
Maybe your slip clutch needs adjusted or maybe its stuck. I don't believe this should have happened had the slip clutch been functioning properly. I have a desk job so take it for what its worth. Good luck.
3,304
1,723
The bolt was either incorrectly installed, "it's a tapered wedge bolt" or the PTO tubes are not greased. The only way pressure is applied to the bolt is through the telescoping of the PTO shaft.
scratchnsniff
2021 L3901HST
Aug 10, 2021
NE Ohio
Thank you.
I'm leaning toward the former.
New bolt installed; confirmed PTO shaft was lubed.
Mak65
L2501 HST
Apr 25, 2019
135
112
TX
I know this is an old thread but it helps to aid in my question. I purchased a barely used LP RGR 1258. Though it was barely used I want to remove the PTO driveline and clean it all up. Make sure its length is correct. And, eventually perform the slip clutch process. The carriage dog bolt (#5 in first diagram) seems to be stuck. I removed the nut and soaked both sides with PB Blaster and left it to soak. I assume I can tap it with a hammer (screw the nut down so even with thread to prevent damage to them. Assuming I get the bolt out is there anything else I may need to remove to get it off the shaft? The drawing doesn’t indicate anything. Hopefully, it’s not frozen on the shaft
5,504
2,213
have seen it and done it
dealer often doesn't have a set amount of material to remove from the shaft ends to shorten it for each tractor so they'll grab one off of the lot, hook up the tiller, and trim the shaft as needed. During that trim/test process, probably didn't get it cut right and bound the shaft up which compromised that bolt. I've done just that. It happens.
Mak65
L2501 HST
Apr 25, 2019
135
112
TX
Thanks Lugbolt but as I mentioned I jumped on to a very old thread. Yes, I do want to make sure the shaft length is correct for my setup.
However, my question relates to the bolt (#5 in first diagram above). It appears to be stuck on my pto shaft. I’ve put PB Blaster on it and hope it breaks loose when I get back next weekend. I assume I can hit it with a hammer without damage to it or the shaft. The diagram doesn’t show anything further but is there a c-clip or anything else that may hold it on if I get the bolt out?
Sporto
B2601-1, FDR1660, RTA1258, BB1560, LR1672, PFL1242, MK Martin Snow Blower
Mar 20, 2021
72
Manitoba Canada
Because it is tapered it will stick in the hole and requires to be tapped out, I have had to do that with mine. Just remember to protect the threads when you are tapping it. (you have to tap on the threaded end)
Mak65
L2501 HST
Apr 25, 2019
135
112
TX
Thanks Sporto. I intend to run the nut down to just before the bolt end clears it. I should be able to give the nut/bolt pretty good taps like that,
