BruceP
G5200H
Aug 7, 2016
852
373
Richmond, Vermont, USA
After sitting outside with cover for about 3 months (several weeks below 0F), I put charger on battery for several hours. I was surprised that the battery was still at 12.3 volts before topping up its charge. (indicating a good battery at 20F)
9,377
It was. Kinda bit my own fault. I had taken the hydraulic ram off the door to replace it and didn't tell her. She was moving an old diesel tank an left the door open and the tyre popped it. :rolleyes: At least the glass didn't break thanks to all this rain and the soft ground ;)
It didn't break the glass? :eek:
If so, your lucky! ;)
Chilliwack Murray
B7510 with loader and BH4672 backhoe, JD400 industrial Backhoe, B6100.
Jan 8, 2019
BC, Canada
Buried power, water and lots of spare conduit to the shop and added a riser to the septic tank clean out for future use.
Slow and steady wins the race and doesn’t break anything important that you don’t want to have to fix.
check 6
BX 2680 FEL and pallet forks aerator ZD1211, RTV500
Apr 8, 2019
Seguin, Texas
Just looked at it rain all last week and ground very soft . When it dries first thing out is Kubota mower
bearbait
Dec 9, 2011
4,138
892
New Glasgow Canada
Coming down pretty heavy here right now with up to 20c coming. Depending how close to the coast you are we could have a change over to heavy rain. If we get all snow I won't bother cleaning it up because whatever we get wouldn't last now.
BAP
Dec 31, 2012
3,031
1,147
Dropped the loader and put the snowblower back on to blow the 9” of snow we got last night. Almost changed yesterday afternoon before it snowed, but given the track record of storms this year, I figured if I did, the storm would not amount to anything and be a waste of time.
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
I got tired of waiting for this drift on an access road on my 40 acres to melt, so got after it. Real compacted and solid, it took the loader to break it up into manageable chunks, and took about 20 minutes. And then, I discovered for the first time, the built in shovel holder!
bearbait
Dec 9, 2011
4,138
892
New Glasgow Canada
Nice tractor however and don't take this the wrong way but you need to down size your photo's and if you're going to leave the hydraulic lines disconnected it would be wise to pick up some plugs or covers for the fittings...it will save you money down the road.;)
9,377
Another trick with lines like that is connect them to each other, that way they stay clean, non pressurized and if you hit the third function control it won't dead head any of it. ;)
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
Wow!, my laptop screen is maxed out, need to get a 55 inch screen to view these pics.:eek:
emt0423
B2650 HSDC
Mar 8, 2019
Wisconsin
Cleaned the goat pens in the barn and spread the manure on the field before all the rain gets here.
johnjk
Apr 13, 2017
1,685
1,860
West Mansfield, OH
Went back in the woods to build a couple monitor stands for working from home.
Windfall beech still a bit wet so they are resting in plastic till they dry out. 5min work with the chainsaw.
