Ballast Box or Homemade Carry All?
robert2601
46
15
Afton,Tn
I bought a b2601 (has not delivered yet) with a front end loader. I will be a rookie user and have a question about ballast. I have 3pt pallet forks and a homemade carry all. The carry all is 48" x 48". My thinking was I would pile some bags of top soil, quickcrete bags and other stuff I have laying around on the carry all for ballast. Should I go with the bulky carry all or forget my cheapskate tendency and buy a ballast box?
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
I put a box blade on the back for ballast most of the time. It comes in about 500# with the QH. The advantage of the ballast box is stability and size. Your carry all sticks out over 4 feet. You can get in tighter places with a ballast box. Secondly when you pile bags of stuff for weight, depending on the ground, could shift or fall off creating a balance issue. Decent ballast box about $300-350 and the the sand or concrete. When you look at what you have already spent that is pretty cheap for stability and size.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,359
1,788
Western MT
I think you’d be better off with a working implement like rear blade, box blade, grader/scraper etc. The only advantage of a ballast box is being shorter.
I bought a ballast box and haven’t used it since I got my grader/scraper and rear blade.
ctfjr
L3800HST
Dec 7, 2009
1,879
2,293
central ct
I think it depends on where you plan to use your tractor, congrats btw. If you are just doing field work anything will do. I go into the woods all the time and its a pretty crappy feeling to be turning and feel a jolt as an implement catches a tree. For that reason I went with a ballast box.
robert2601
46
15
Afton,Tn
I am not too concerned about getting in tight spaces as I will mostly be using fel on open ground but it is a sloping area and I agree about the bags of stuff shifting. But I am in luck-I have a 5' box blade but I have no idea how much it weighs. Will try it first before I go with a ballast box. thanks
robert2601
46
15
Afton,Tn
Thanks, I have a box blade and will try it for now
robert2601
46
15
Afton,Tn
Thanks, Appreciate the info
old and tired
L2800 HST; 2005; R4
...I have 3pt pallet forks and a homemade carry all...
Cheap works... no need to to buy a ballast box. I built my "forks" to be used for several things, sprayer, carry-all, and a ballast 'drum'. I do have a dedicated pallet forks for my pallets of firewood.
If your carryall turns out to be too bulky, I would change it out later. Try it first! I do use a box blade as ballast at times, better than just a Box.
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
Run ballast box whenever rear implement isn't needed. Only takes a few minutes to swap implements when using QH, parking stands and having implements properly setup
5,255
My opinion, but in open ground with both a carry-all and 5’ box blade, you’re all set!! ;) :cool:
5,255
Of course, I’m not impartial…..never saw a need for another implement. It is true that a ballast box can be more compact, but I can accommodate.
ctfjr
L3800HST
Dec 7, 2009
1,879
2,293
central ct
Nice job RCW !
One big advantage to a carryall like you show is it moves the ballast weight further behind the rear axle. Its like a multiplying effect on the actual weight you have on it. ie if a ballast box has 600lbs of weight centered 30" behind the axle you would only need 400lbs centered 40" behind the axle. If you put 600 on your carryall a ballast box would need 900 for the same effect.
The distances I used are just for illustration but I think I get my point across.
robert2601
46
15
Afton,Tn
I am getting a lot of votes to use what I got. I am pretty sure I am going to practice with my carry all or box blade. Nice job on your carry all.
5,255
Nice job RCW !
Robert - - like ctfjr said, the carry-all moves weight back aways.
I figure the carry-all weighs about 200 pounds +/-.
Without the loader on, I had almost 400 pounds on the carry-all couple summers ago. Was wet bags of topsoil and wet mulch.
Front tires were pointing skyward......being stubborn, I got stuff moved where I wanted. Kept wishing for individual wheel brakes.
It does demonstrate ctfjr's point. Wouldn't have been an issue if the loader were on.
robert2601
46
15
Afton,Tn
Does this mean that when using the box blade I will need the front end loader to be attached?
TomRC
160
106
KY
I built this carry all from a King Kutter frame about a month ago for my B2601. Plans at DIY My Way. It has already been used for spraying, hauling seed, fertilizer etc and carrying weedeaters and other tools around my place to do work. Side panels fold in. I still need to build the removable tail gate from a couple of 2x10's. Very useful for multiple purposes!
5,255
Not necessarily. My BB is not overly heavy, and I can use it without the FEl. Front (4WD) traction is compromised some without the FEL's weight, but it's still very much usable. Maybe just can't do real heavy ground-engaging.
If it were an issue, you could add front suitcase weights. However, I'd still hold that in abeyance until you see how it works first-hand.....kinda the same philosophy as not really needing one more implement....
robert2601
46
15
Afton,Tn
Thanks RCW This forum is an educational experience for me. I appreciate comments from guys that have been there and done that.
