different tire sizes
alpha33
Kubota B3200
Sep 8, 2021
Vermont
I have a Kubota B3200 I bought new 10 or 12 years ago. The original front rim is 7.00-12 and the tire size is 180/85D -12. This past weekend I found a pair of rims/tires off an older B7800, rim size 7.00-12 and the tire size is also 7.00-12. This set of rims/tires fit perfectly on my tractor. My question is about how much taller the 7.00-12 tire is compared to the original tires. They are approximately 2 inches taller. Question is, will this height difference create or cause problems/damage to the front end or rear for that matter?????
The tire on the left is the original.
Thanks alpha33
2,858
Alpha
at 2" taller..... that is going to be a hellva difference in RC..... which will not make the drivetrain very happy!
If you use them - I would not use in 4wd!!!
Typically in all 4wd scenarios - the fronts "pull" the rears a bit, in your case it is gonna drag them!!!
I would tread lightly here!
Rbmedic75
L5030
Sep 9, 2021
WV
Don’t mean to hijack a thread by any means but similar question. Recently bought a L5030 with R3’s that are well dry rotted. Put same size new on the fronts already which are 29 x 12.50 a 15. Noticed it seems to drag in 4 wheel so started researching. The rears are 44 18.00 - 20’s. Using factory rolling inches specs my lead lag is 7.69% which appears to be out of recommendation. Wouldn’t mind a little taller tire in the rear and a rolling circumference of 136” would get me to 4.76%. Any knowledge of what tire size I should be looking for in an r3? Would like to keep same rim if possible
2,858
One thing to do to cheat the system is to deflate or inflate the tires a bit - this will change the RC a bit, probably not enough to really matter but as mentioned once you get past about 2-3% lead-lag, bad things tend to happen.
Rbmedic75
L5030
Sep 9, 2021
WV
Thought I would post this back on here. I learned something today while trying to sort through the lag time issue I mentioned above. So not all 44 18.00 -20 tires have the same RCI. Titan 6 ply have a rci of 132.3” with overall diameter 44” while the Titan 4 ply (both R3 turf tread) have a rci of 135” and overall diameter of 45.9”. Kinda BS but is what it is. The kubota L5030 with 29 12.50 -15 fronts needs the taller 4 ply. Changes the lag time from 7.35 with the 6ply to 3.56 with the 4 ply. Ain’t that some crap..
thirdroc17
185
35
Just goes to show the most important specification, which usually isn't listed, is rolling circumference. Many people will insist "same size", which doesn't mean squat.
