B3030 saftey switch fun. Won’t even crank
Average@best
Kubota b3030 w/cab
Sep 6, 2021
Pennsylvania
I have a b3030 that abruptly died on me last week when I put the seat forward. Hasn’t cranked over since. Pulled the pto pedal switch, bench test checked out.
Replaced both seat switches. Checked the saftey switch on the trans the best I could, no obvious issues. Now I’m at a loss. The funny thing is it will blow a fuse every time I put the seat forward and have the key on. But I still can’t even get it to crank. Please help 😵💫
Pau7220
Aug 1, 2017
785
280
Scranton, PA
Take a close look at the wiring that goes to those seat switches, or anything close to it like where it comes through the body. Chances are you'll find something pinched, broken, or shorted.
5,255
1,056
A good first step would be to download the free WSM on Kubotabooks.com
I add the caution that these free WSM sometimes are coming from countries other than North America and the safety systems in them can be less involved than is really on your tractor.
For example, I know your tractor has a seat switch but there is no mention of a seat switch in the WSM
WSM
The safety switch situation is totally dependent on the transmission you have as shown below.
Without the WSM just finding all the safety switches is a challenge
Paul7720's advice about checking for frayed wires is most valid but focus your looking on the switch locations.
Besides checking the safety switch wiring, check around the starter relay as all safety switches are in this circuit.
Unplug the starter relay and see if the fuse blowing stops.
Love Kubota’s
2006 B3030 with Cab
Jun 15, 2026
LA
We have the same problem. Did you find the problem?
nbryan
Jan 3, 2019
1,415
934
Hadashville, Manitoba, Canada
After analyzing whitetiger's first attachment, there's a seat tilt safety switch which is normally open, so I assume it would close when the seat gets tilted up. Then the fuse blows. The PTO Shift Lever Safety Switch is between the tilt switch and the controller. That switch you say checks out as normally closed.
I'd remove the 5A fuse and use a multi-meter to check continuity to ground at both terminals of each of the Seat Tilt and the PTO Shift Lever Switches. Seems a lot like that circuit has a grounding short to frame somewhere. The wire on its way to the PTO Lever Switch (0.5 LY) and the PTO Shifter to Controller Pin 4 (0.5 Or) is shorting to ground?
