I needed to flush some bad fuel from the tank, and wanted to connect my battery charger to keep the battery up while I used the BX's pump to clear out the tank. Found I had some corrosion on the + terminal! No problem, I can clean that up.
Once I removed the crusty corrosion, this is what I found:
Maaaaybe I let that go uninspected a bit too long!
