LX 3310 Key On Battery Power
sardillim
b2650
Nov 24, 2019
114
40
Easton
Would anybody know where i can get battery power with the key on ? I Looked at the fuse block and there are only two open spots with no power
thanks
B737
LX3310
Jun 9, 2019
2,024
2,200
front or back? if you are looking in the back there are two bullet plugs that are switched with ignition on. I believe they are good for 10 or 15 amps. While looking at the hitch, you'll find them in the top 3rd of the right side harness.
4,910
could be 'hidden' under blue electrical tape, least they are for the BX23S series. rest of harness has black tape on it. 3 bullets, male is ground, female is +12 live, other will be 'switched' +12.
sardillim
b2650
Nov 24, 2019
114
40
Easton
Should have mentioned my machine has a cab, looking for switched power inside the cab
Njtool
Lx2610 HSDC. BH77 backhoe
Jan 1, 2021
216
281
New jersey
You might get better answers if you clue us into what you need the keyed power for....
4,910
The WSM for your tractor will have the wiring diagram,should show 'switched power',at least if it's prewired( I suspect it is..). It might say 'work lights or '3rd function''... I'd have to see the diagram to confirm.
Old_Paint
Dec 5, 2020
1,734
1,730
AL
All the user access wiring on the LX series is marked with blue tape. IIRC, everything is switched with the key/pilot relays except the feed to the key from the battery. The OM shows locations for most of them, but I have no clue about any wiring differences in cab or no cab models. I do know that one OM covers all LX models. As for a WSM, haven't found one for the LX yet.
sardillim
b2650
Nov 24, 2019
114
40
Easton
So all i was only able to find was battery power. in the left rear of the cab. seems to work ok since the sub woofer i added requires a connection to the audio receiver and won't turn on unless the the receiver is on.
This was the project
Removed the interior, and dynamatted the inside of the cab, also added a new audio receiver , front speakers , sub woofer and new rear speakers
