The Piranha is also good stuff. It’ll make your bucket a lot more aggressive and useful for digging in tough clay and roots. Got one of those too. Just make sure you give instructions to NOT put it on anything the shipper doesn’t want to pay for. BXpanded doesn’t package the bar sufficiently for long shipping, and the cardboard box tends to be the tooth bar’s first victim. FredEx wound up writing a check for nearly $600 because of the mishandling of the package and then careless handling again when they pushed the destroyed package onto my front porch with the teeth turned down. Those teeth are VERY sharp and will do a lot of damage. After you install it, quickly develop a habit of putting the bucket flat on the ground when you’re not using it. You do NOT want to bump your head on it, nor any other body part. It’s a bit dangerous to leave it up, especially if you or someone else is working near the bucket edge. Mine sliced right through the side of a Red Wing safety boot. But I still like the product. I just got the Titan short pallet forks as well. They work just fine over the Piranha. The Piranha makes for a little less variation of width because of the teeth, but I used mine today to unload the new roll-up doors for my new shop. I went with the light duty forks (1500 lbs) because the LA535 is only good for 535KG (1200 lbs) at the bucket (SSQA) pins. Not much point in having something that can bend my bucket or FEL boom.
