D
Deleted member 47704
Guest
I peed on the tires, since I no longer have a dog to do it for me....
Did you know that urine acts like traction compound? :ROFLMAO: not really but its fun to see guys peeing on their tires
6,262
Well, that’s just sad. If you want a cat, I can hook you up. Don’t have any spare dogs. Cat will climb all over your tractor, but he won’t pee on it.
7,309
I didn't do anything, I might put my Boltonhooks "Don't mess with my tractor" sticker on it later on.Maybe drive it around just because
I didn't do anything either....
Didn't pee on the tires, though. Made me laugh.
"Ollie" is having some health issues, but is still covering the job when needed....for now...
I did get a new battery last weekend. Rain tomorrow morning. Might be a good opportunity to get that change done. Had it on a Tender for a couple days to charge it up.
D
Guest
I put the sticker on the side of the dashboard/cowl.
Did some other stuff, moved a huge bag of perlite.
Prepped generator to be moved.Stationary unit weighs about 500 lbs.
Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Finished building my cherry picker. Has a shelf, wire under shelf for gloves, rack for the pole saw etc. that was fun. Christmas lights B8CFB262-2AB1-4E5E-B2DD-54E155D2A119.jpeg 0CB05B79-E14D-4C51-9E64-1C15B88769AE.jpeg FE74E410-76FF-4EFB-B7C0-FF025089D466.jpeg will be a lot more fun putting up this year.
Reactions: 7 users
PaulL
B2601, MX5200.
Jul 17, 2017
2,780
1,777
NZ
Ratchet strap to hold the cage onto the pallet forks? I need to make one too, so like the look of what you're doing. I have to visit brother in law to get a cage from his chemical tanks.
Your pole saw looks a bit like a string trimmer!! (I have the same combo system, so yes, I know it has a pole saw attachment)
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,688
4,393
PEI Canada
Mowed the rest of the grass and took the deck off. Put the forks on and pressure washed the deck.
Put that away and switched out the forks for the grapple
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
62659FEC-7857-49FF-BCC5-8301828E3F38.jpeg 4A15BEE7-45F9-42AE-87CE-BC3B00B52D33.jpeg 0B6DD8CC-8751-4B1A-988F-3A226886E94C.jpeg
Moved my tractor out of the garage to put oil cans on the new shelf i built. Anyone else in here collect oil cans or petroliana?
Goz63
Jun 19, 2021
299
349
Mississippi
Lol yeah it is the Stihl combi system. Just have the trimmer head on it. I have a ratchet to hold it on but didn’t put it on for the pictures. Put the forks and picker away in the barn and put grapple back on. Getting ready for the hurricane. Looks like this one will be at least a Cat 4.
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
5,160
Very cool man. I have Some nos oil filters laying around. Do you collect only vintage? Or new as well?
I go to the extreme... Corvair oil filters, because I have a Corvair, and the oil filter that the Corvair uses, is not used on any other vehicle known to man (or woman, to be politically correct). I have them in cases of 25 filters to a display case. Last year, a friend built 4 additional cases for me, but haven't gotten around to putting filters into them. I should have asked him to built more, but I didn't want to push my luck. The first 4 I built in my father in laws shop, but he passed away, and I don't have a wood working shop.
RichardAaronlx2610
Aug 3, 2021
454
522
New Jersey
Post up some pics! I actually Scrapped a few corvair motors earlier in the year. We pull them out of the old volkswagens and put vw motors back in them. That’s was the hot swap back in the day. Until parts became obsolete
Old_Paint
Dec 5, 2020
1,990
2,215
AL
Got a Pirahna tooth bar coming, who knows when. Debating on waiting and trying it or getting a Titan
The Piranha is also good stuff. It’ll make your bucket a lot more aggressive and useful for digging in tough clay and roots. Got one of those too. Just make sure you give instructions to NOT put it on anything the shipper doesn’t want to pay for. BXpanded doesn’t package the bar sufficiently for long shipping, and the cardboard box tends to be the tooth bar’s first victim. FredEx wound up writing a check for nearly $600 because of the mishandling of the package and then careless handling again when they pushed the destroyed package onto my front porch with the teeth turned down. Those teeth are VERY sharp and will do a lot of damage. After you install it, quickly develop a habit of putting the bucket flat on the ground when you’re not using it. You do NOT want to bump your head on it, nor any other body part. It’s a bit dangerous to leave it up, especially if you or someone else is working near the bucket edge. Mine sliced right through the side of a Red Wing safety boot. But I still like the product. I just got the Titan short pallet forks as well. They work just fine over the Piranha. The Piranha makes for a little less variation of width because of the teeth, but I used mine today to unload the new roll-up doors for my new shop. I went with the light duty forks (1500 lbs) because the LA535 is only good for 535KG (1200 lbs) at the bucket (SSQA) pins. Not much point in having something that can bend my bucket or FEL boom.
Goz63
Jun 19, 2021
299
349
Mississippi
Very nice. Osha would love this haha. Do you at least have a safety chain around it in case the operator hits the wrong lever?
Yeah I put a ratchet strap through the back and around the forks. Holds I tight.
D
Guest
Wish I knew that before I ordered it. I'm going to cancel it.
