Hi, I just changed the hydraulic fluid, filter (and cleaned the strainer), and a bunch of cracked hoses on my BX2200 and LA211 loader. After all of these changes, the FEL isn't working correctly. It moves up alright (not perfect), but doesn't move down very well. Curl only works an inch or two in each direction, and not every time I press the lever (but it does work a little). I drove it around for 30 minutes and the loader moved a little bit more than it was moving right when I started it up, but nothing substantial.
The main recommendation I've seen is to re-seat all of the quick connect spots, which I did. Someone also recommended I switch the boom/curl lines to see if it was an issue with the control valve - after switching the connections I got the same performance - up worked alright (albeit I was pressing to the right instead of down) and the other three directions didn't really want to move. One item of note is that one of the female QC connections did NOT want to close, despite me relieving the pressure before trying to disconnect (assuming that moving the joystick in all directions is the right way to release the pressure). Both times I had to unscrew the hose the female fitting is on and relieve pressure manually (as well as let a bit of hydraulic fluid out). This was NOT one of the hoses I changed though.
My mechanic friend (who lives in a different state and is helping me over the phone) thinks I have something restricting flow. He recommended disconnecting the hoses from the control valve and blowing air through all of the holes on the valve to ensure there aren't any obstructions. In his line of work the control valve has the smallest ports and is most likely to clog, but he works on giant machinery not hobby tractors and I don't know if that's the same with small tractors.
My gut tells me its has to do with that QC fitting that isn't working right. If its not relieving pressure the "usual" way, that seems like it could cause my issues because its restricting flow. I however am an accountant by trade, and they teach very little mechanics in accounting. I don't know if my theory holds water or if my FUD around trying to blow out the valve is making me hope I just need to change a fitting, even if it does cost 30$.
Not sure what other info might be useful. its a 2005 with the bx2014 4pt hydraulic valve. 1070 hours. I've had it for about 4 years. I have not been a good tractor owner, but its not in terrible shape. I didn't drive it for a while, but the last time I used it I didn't have these issues. Per the dipstick, I have the correct volume of hydraulic fluid in it. It *kind of* sounds like its leaking air when i turn it on, but its so loud im not sure if im imagining it or not. Ive run it for about 50 minutes since changing the fluids/hoses and that seems like a long time to take to bleed air out of the hydraulic system (albeit I have absolutely 0 frame of reference).
Thank you for reading this far and I truly appreciate any help you can provide.
