Is there a way to slow down the drop rate of front end implements like the 3 point adjustment does for the rear? When trying to work with finesse with forks, my drop speed is way faster than I would like.
I'm new at this as well and found the jerkiness of the drop speed to be surprising. I had pallet forks on and slid under a pallet of loosely stacked beehives (without bees in them thankfully) and they all tipped over on the way up....I re-stacked them on the raised pallet and they all fell over again on the way down. Ended up using straps but I guess maybe practice will help.
[/QUOTE
I recall forum guru NIW discussing this topic a couple of years ago.
I think he was talking about using this type of adjustable flow control which allows full flow in one direction and throttled flow in the other.
You restrict the flow when needing precision and then open up the control at other times.
Bailey adjustable flow control
Depending upon your needs, you might need one valve on your up circuit and an other on your down.
I have not done this before so before just following my advice ask at hydraulic suppliers.
thanks for the quick response. I will definitely look into this.I recall forum guru NIW discussing this topic a couple of years ago.
What happens IF you raised it about a foot off the ground and slapped it INTO float mode - does it drop like a rock?Yeah, seems like using the forks is where I really noticed the problem. No doubt due to the weight distribution being shifted so far forward compared to a bucket. Still, sure would be handy to be able to choke the flow back when necessary. I would say moving bees is definitely a time when extremely smooth operation would be appreciated.
Never tried that, but will check this evening and report back. ThanksWhat happens IF you raised it about a foot off the ground and slapped it INTO float mode - does it drop like a rock?
Without forks on it - float drop fast or some what slower than normal usage ?
Yeah, I did some testing last night and it appears my biggest problem is when I tilt the forks and lower at the same time. Like moving into a stack of pallets or positioning under a round bale. I also tend to fold my forks straight down and lower to the ground to park, since my current parking spot is a little cramped. I guess I don’t perform those same actions with the bucket. Add to that the fact that the forks slap pretty hard due to the play in the sliding mechanism and that loud clank helps contribute to the overallPretty sure the loader was designed as a 'loader' NOT as a 'forklift'. After 3 years(600+hrs) I'm still not good at 'forklifting'. It'd be costly to make it smooooth,like a forklift using either a LOT of 'plumbing and parts' or $20 for a micro and a few lines of code. The 1st could look like the Three stooges bathroom reno, the 2nd is on my 'todo project' list.
I did find that less RPM helps, as well, bracking your arm on the arm rest and CONCENTRATING ! You've got to 'feel' the valve open, NOT have kneejerk reactions either and of coures it all changes depending on the weight of the load.......
Thanks again for all the input guys. And yes, I’ll agree there is never a substitute for good old fashioned practice. I guess I’m just surprised by how slow I am to gain control with the forks, but the backhoe came pretty easily. I was reasonably comfortable and competent with the backhoe after the first 10 or so hours and having never run one before. Here I am at 170 hours in and still clunky and funky with the forks.If you have arms rests, use them to steady your arm and use fingers to operate stick.Not your whole arm.
Real fork lifts require stick feel to operate smooth. I use a 4000lb capacity fork lift a couple times a week. Before covid hit I was supposed to become a forklift trainer. We're operating on a skeleton crew right now so its tabled.
Gives you a reason to do stuff with the tractor.Thanks again for all the input guys. And yes, I’ll agree there is never a substitute for good old fashioned practice. I guess I’m just surprised by how slow I am to gain control with the forks, but the backhoe came pretty easily. I was reasonably comfortable and competent with the backhoe after the first 10 or so hours and having never run one before. Here I am at 170 hours in and still clunky and funky with the forks.
The description you have doesn't sound like my BX. So maybe you have something wrong with the machine.Folks, I’ve got to revisit this discussion again. With forks on my Bx23s, the drop speed sure does seem to be excessive. Ive got to seriously concentrate and just barely touch the controls to avoid a major drop with empty forks. Why is this so touchy compared to the 3 point controls, back hoe, front end buckets on other equipment I have run not to mention the countless warehouse forklifts I’ve use. Is this just the way it is with this design, or do I possibly have a problem? Any suggestions to remedy are greatly appreciated. Thanks
