Hello,
I have consulted my manuals and read as many threads on this site as I can find, but still I have a question about spill timing, or at the very least if something else besides shimming could be wrong with my tractor.
When I did the spill timing, I couldn't believe the timing shows as being at (or near) TDC. That's about 20 degrees retarded, right? Is it possible that there's a shim missing in the plunger, or the tappet roller is worn out, or the actual cam is shot? It just doesn't seem like needing to remove 8 shims is reasonable, and I have not yet checked to see if I even have that many shims. Is it possible the gears are out of phase? The injection timing seems terribly out of whack!
I have a full tank of fuel, I set the throttle to full, etc. It doesn't say in my engine manual, but am I supposed to bypass the lift pump?
Engine does not want to reach PTO speed (since I've owned it, about 3-1/2 years).
Injectors were rebuilt by quality shop.
Clean fuel filters, good steady flow of fuel to lift pump.
Probably shouldn't matter, but this spring I put a reman head on it with Kubota parts and gaskets, and did a re-ring and new rod bearings.
This tractor was ugly when I bought it, I thought that, being a little tractor in big tractor territory far from the city was why it was relatively cheap.
