OK, I have two hydraulic elbow fittings that leak. They are 3/8 NPSM female with the o-ring inside going to a 3/8 NPT male. I have the same configuration on another line with no leaks. I tightened them twice, but still leaking. I understand/read that sealant is not needed on the NPSM due to the O-ring seal and did not use any on these or the other two not leaking. Should I try sealant on the threads? Arrow is the NPSM nut where the fluid is leaking.
