My fellow orange tractor owners, i am in need of some advise. i need to remove the front axle on my L225DT in order to gain access to one of the four bolts that hold the pinion housing to the front diff/axle housing. One of the four bolts broke the bolt head off. See pics. Anyhow, from what can tell it appears the from that supports the front axle is a single piece but obviously it has to come apart some how in order to get the axle in and out. I see the lock nut that holds the shaft that the axle pivots on but not sure how it would come out other than from the rear/engine block side? Any advise is much appreciated.
