BX23 Top Link
chriscozi
BX23S 3rdFunction TerraKingBagger 4ftBoxBlade 5ftPlowBlade 3ptQuickHitch
Nov 26, 2020
42
17
Rutland VT
www.sugarwoodschool.org
Hi all,
Sorry if this has been asked and answered.
When I take off my backhoe I have all three connections available for other attachments.
I should be able to add a 1 or 2 valve open center assembly and connect it to top and tilt cylinders, correct?
I think Kubota should offer this as a kit.
Your thoughts and comments?
chriscozi
Nov 26, 2020
42
17
Rutland VT
Wow. With the weekend and all the top link and third function posts on this forum I assumed my post would get a quick reply.
MOOTS
MX6000
Jun 27, 2019
1,921
2,200
Canton, Georgia
You want to use the backhoe hoses connected to a valve that is removable, to operate t&t while hoe is removed?
4,814
Hi all,
Kubota did many years ago, and I have the one that I removed from my BX22, because the valve failed. It is available as a non working part. Open to offers.
KUBOTA BX REAR HYDRAULIC REMOTE KIT BX7322
There is one listed on eBay for the last year or so.
chriscozi
Nov 26, 2020
42
17
Rutland VT
Thanks.
Good they used to sell one but why not have one on the machine as an option like on the front where I have the third function? It's already plumbed to the rear for the backhoe.
4,814
Kubota sells a 'deal rear remote kit', levers fill that empty slot in the right fender.......
They do for the BX23S, but not for the BX23. I am assuming that since he refers to his machine as a BX23, that it is about 16+ years old, and most of the kits that were sold for those machines are not obsolete. The kit for the rear remotes for a BX23S is $1000+. I have been considering it for my tractor, however, I don't believe that it is worthwhile for me, since I wouldn't use it very often.
MOOTS
MX6000
Jun 27, 2019
1,921
2,200
Canton, Georgia
Wouldn’t a 2 spool valve and some hoses do this?
Connect valve to backhoe hookups(hoses and quick connects), t&t to each spool. Hardest part would be making the valve sturdy, and easily removable.
4,892
in his 'equipment list, 1st item is a BX23S...so I assumed that's what he wanted it for...
at $1000, not a bad deal for something 'plug and play'.....
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
It IS possible to install that kit on a
Does it fit the BX23s? On the older BX24 and BX25 you couldn't install it du to interference with the backhoe frame. I did cut away enough of the frame on my BX24 to install it but I don't really recommend it because of the weakening that results. ( I rarely use my BH but I do use the remote valve fairly often)
hoening
BX23S w/FEL,BH,& Snowblower, York Rake, Box Scraper
Jan 2, 2011
27
Cary, IL
The Kubota rear remote kit will not fit a BX23s due to the backhoe frame. removing part of the frame would be an option but???
