shootem604
Apr 23, 2018
874
British Columbia
Ran my backhoe on the L245 to dig up material for a concrete pad while moving it with the L245DT FEL
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
Columbia, CT
Finally Finally I got Holly to drive the tractor on her own this evening to pick up her brush piles! I've had it over a year - and I've always had to be around to move the tractor!
edritchey
Ferris IS800Z - New Holland WM75 - John Deere X500
Jul 19, 2014
1,121
825
Wellsville, PA
Now you will never get her off of it LOL.
I haven't looked at the BX series in awhile but don't they come equipped with a draw bar anymore?
Looks like a lot of attachments on the back of you tractor just to pull a cart around. ;)
bearbait
Dec 9, 2011
4,104
879
New Glasgow Canada
Don't forget his beer bill will be going way up. :D
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
Got 2 yards of crushed stone. Got yard drainage pipe and stone in the ground and partially covered.
Then noticed I broke the little beast.
shootem604
Apr 23, 2018
874
British Columbia
Oops!
I dug a trench along the house with the backhoe for a perimeter drain.
michigander
547
234
Northern Michigan
Removed loader for 1st time ever today .. easy job :)
Planned on using mmm for 1st time I gave up .. the adjustment dial wont budge.
Spent the afternoon mowing with old cub cadet
Nomore67
Currently own- LX4020, B2601, IRE20 (mini-ex). Previously owned- BX1870, B2601
Apr 28, 2019
29
38
Minnesota
I'm sure you had raised the deck before trying to adjust the MMM height... If not, that was likely why the adjustment knob wouldn't turn.
greeno
B2710 w/LA402 FEL, BL4690 hoe, RB1560, GS1560, Haban 5' sickle bar, 5' JD RC
Jul 14, 2018
187
Big Lake MN
Put on a regular seat belt to go with the spring seat:
Among many projects, I helped the women folk with a garden project by using the ripper teeth on the grading scraper to loosen soil:
SidecarFlip
Banned
557
I was busy today. Pulled the cast center 34's on the back of the new / used M9, pulled the center section out, adjusted the proportioning valves for the pto pack and the travelling pack and gave her a bath underneath.. and changed the hydraulic oil and filters. Next comes the new seat and suspension and then the canopy I ordered a while ago. Still need to change the engine oil and filters (fuel and oil).
Glad I had the CACL sucked out and retubed them. I bet each wheel and tire weighs close to 1000 pounds dry. Don't want to let them out of vertical or bad things can happen real quick. Besides, the 34's are as tall as I am (6 feet).
She will need new Titans next spring., but the Firestones on it now will run this summer. At 500 bucks a tire, I'll have to save my pennies.
She's sitting on jack stands in the back right now.
It's only money....lol
6,634
Can you get Titans for $500 in that size? I've been on the outlook for some 16.9-38 for my 730 Case. They're scarce and expensive when I find them and made in a far off country!
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
Used the backhoe to bust up the garden soil and mix in compost. Hooked the rake up to try to level the garden out (blasted thing doesn't fit to the quick hitch). Moved some compost to some other areas then mowed. A good day tractoring.
Sent from my SM-N960U using Tapatalk
shootem604
Apr 23, 2018
874
British Columbia
Moved some junk to my burn pile and torched it before the burning ban comes in later this week.
SidecarFlip
Banned
557
Sure can, my tire distributor (who handles my tractor and automotive tires) is a Titan distributor. Already quoted me a price on 38's. I can even get them with new rims mounted if I want.
I've found that Titans wear best for roading than anything else. Not radial, bias ply.
johnjk
Apr 13, 2017
1,621
1,662
West Mansfield, OH
Saturday I built new raised garden beds and used the B to move the soil from the existing beds. Sat evening/ Sunday morning tended the smoker. Monday I got back on the B and mowed. It's a lot quieter with the Pat's Quick Hitch vs the HF unit.
michigander
547
234
Northern Michigan
Sorted out mower deck dial this afternoon
Disconnected arms from deck in the end to free it up I lowered the arms then raised by hand turned dial and re installed arms to deck all is fine :D
Drove to corner gas station for fuel 4.4 gallons
motionclone
May 4, 2018
1,399
996
Maine
Got to use my Greens Machine grapple attachment for my forks:
AND I rolled 1000.0 hours on the meter:
