Was mowing and tractor slowly lost power. After trying to restart (and failing), I ASSumed I had a fuel pump failure. Armed with my motor serial# I went to the dealer and purchased a new fuel pump and fuel/water filter.
Installed both and followed directions to purge the air by turning the release valve on the injector pump, cranking, (engine started running, rough), shut the I.P. valve and it smoothed out, ut was running weak. Gave it some fuel and it died.
That's where I am at now. I took the hose off the fuel pump that feeds the injectors and got just a dribble.
I NEED help, please! What do I do next, bleed the injector lines?
