Automatic fromt quick attach
Mmille57
L2501, loader, pallet forks, 3pt. quick attach, draw bar, box rake, tiller
Jul 28, 2021
First post, wondering if anyone has fabricated their own "automatic" quick attach pin actuation device so you can switch between front implements from the seat of the tractor rather than getting on/off 2x to switch impliments... if someone has posted this, would you be so kind as to direct me? Thanks!
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
Welcome.
Here is a thread that might interest you.
5,900
Used a 4" stroke linear actuator and a DPDTMO switch on my BX23S. Worked fine but slooooooow. One day I should look for a real higher speed version linact.Only mod to SSQA was longer lever/pin joint bolts. As a 'proof of concept' is was clean ( no hydraulic oil) and no hoses !
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
264
64
Southern IL
Be interested in seeing some photos of that setup.
Chuck Woolery
2021 Kubota B2601
Jun 4, 2021
20
10
Wisconsin
First link I could find on a google search.
5,900
BTDT for my BX23S with SSQA. Linear actuator needs to have 4" of stroke, good power and be FAST. The one I chose had the power (ft-lb) but was slooooow. So sloooooow, I took it off. I could increase the voltage to say 24-30,that'd speed it up,but,well 'other things' were more pressing at the time. One day I may look for fast,powerful linact..maybe this fall or winter . If I had the dual rear remotes,silly hydraulic cylinder would work great BUT couplers,hoses, yuck......
Chuck Woolery
2021 Kubota B2601
Jun 4, 2021
20
10
Wisconsin
One thing to keep in mind is someone could double up on two of the cheaper ones with half the force and half the stroke needed, but faster speed. Would get the full stroke required, at the right force, but also faster speed.
Bmccolley
MX6000 HSTC, FEL hooks/Pirahna bar, RB3784,, 72 BB
Oct 8, 2019
11
MI, US
FYI - Electric actuator to open/close SSQA
