BX2660
OrangeKrush
Nov 15, 2020
1,044
517
Indy
YouTube may be your friend on this..
lopinslo2
BX2660, RCK60b23BX
Aug 22, 2011
17
Baton Rouge, LA
They simply snap in there. I "carefully!" pry them out with two screwdrivers .
Thanks. I did that then checked the power to the panel, specifically the power to the temp and fuel gauges. The all had 12+ volts and all the lights come on. However, the temp and fuel gauges do not work. The gauges remain in the same position. Can the gauges be replaced? How so?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
No, they cannot be replaced.( at least not with parts from Kubota!) You will have to replace the whole thing.
7,314
The fuel and temp gauges in the BX60 series can be a little funky.
For the temp gauge, have you messed with connection to the sending unit to make sure there's a decent connection to the gauge?
lopinslo2
BX2660, RCK60b23BX
Aug 22, 2011
17
Baton Rouge, LA
I still have not fixed this issue, but the engine has not run hot either. I want to pull the sensor out of the engine to test it, but I am not sure where it is. Is it on the front, left side of the engine block? See picture attached with red circle around the object.
10,838
You don't need to pull the sensor to test it, just use an ohm meter.
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
103
133
Lakes Region NH and Sonoran Desert AZ
dan_m
BX2380
Jul 9, 2020
199
94
Georgia
Instead of using screwdrivers, I have been using these for a number of years. They cause less damage on plastic. Cheap to, especially if you get on sale.
nylon pry bar set (7.49 msrp)
trim removal tool set (8.99 msrp)
