I have an F2560E, my deck is RC72R-F30. It's vibrating really bad. It seems to be the PTO, gear box or both.
It's possible to be an out of balance blade or bent spindle but even with the belt off the gearbox still vibrates. I tried removing the shear pin/bolt that attaches the PTO shaft to the gearbox and there still seems to be some vibration. The U-joints don't seem to have any noticeable wear so I can imagine those are bad.
It's so bad it's caused one of the mounting bracket tabs to break off where it bolts to the deck. I welded it and put new bolts all around. Now the tab has broke next to my weld.
Has anyone here experienced this problem and what may I ask did you find?
