I don’t have your tractor but per the owners manual…
Bleeding procedure is as follows:
1. Fill the fuel tank with fuel ,and open the fuel cock.
2. Loosen the air vent plug on the fuel filter 2 turns or so.
3. Turn on the key switch and wait for about 1 minute. Then tighten up the air vent plug.
4. Set the hand throttle lever at the minimum speed position and turn the key to "START" position.
If the engine doesn't start, try it several times at 30 second intervals.
A Do not hold key switch at engine start position for More than 10 seconds continuously. If more engine cranking is needed, try again after 30 seconds.
5. Accelerate the engine to remove the small portion of air left in the fuel system.
6. If air still remains and the engine stops, repeat the above steps.
