KbotaL185DT New member Equipment Kubota L185DT (sold),Kubota B7800, LA402, 5 foot Bush Hog Squealer May 29, 2020 19 27 3 Rangeley, Maine Jul 21, 2021 #1 Built these tie down hooks for trailering. Just used a thick wall angle iron and angled the edges. Reactions: 1 users
J Jared 756 Member Equipment MX5400, L3901 and B2601 Jun 9, 2021 55 34 18 Washington st Jul 21, 2021 #2 Do you use a slip hook then or a clevis?
KbotaL185DT New member Equipment Kubota L185DT (sold),Kubota B7800, LA402, 5 foot Bush Hog Squealer May 29, 2020 19 27 3 Rangeley, Maine Jul 21, 2021 #3 Jared 756 said: Do you use a slip hook then or a clevis? Click to expand... I use 4 10,000 lbs double hook ratchet straps on the tractor. Then I have two 1.5 inch 3000 lbs sex straps I use to secure the attached implements. Reactions: 1 user
FTG-05 Active member Equipment L4330 w/FEL, RTV-XG850 and ZD326S Jul 21, 2013 286 121 43 TN Jul 21, 2021 #4 Tell me more about the sex straps, please! Reactions: 4 users
M Motion Well-known member Lifetime Member Equipment Kubota MX5100HST/FEL Aug 17, 2020 543 305 63 Mandeville Louisiana Jul 22, 2021 #5 The brackets will hold, my only comment is the two bolts holding the bracket are shorter by the thickness of the angle iron and not using the full depth of the threaded hole. Just my .02
