I have been searching, but I haven't found the exact scenario played out.
I recently changed both fuel filters on my tractor and now it runs fine if the tank is full, but when it gets down to around 3/4 full, it starts sputtering and loss of power like its not getting fuel. I can fill it up and it will run fine. I guess it sounds like either the tank is clogged or water in the fuel. Just found it was strange until the filter change. Any ideas? FWIW, I have tried bleeding it and puled the line off after the pump to confirm the pump was pumping a steady stream.
