Mystery to me
Arkansas Dave
L185, Frontier GM1060R finish mower, 4ft box blade,middle buster, behlen blade
Jul 12, 2021
47
17
Arkansas
I noticed something which I think might be a cover but not sure. On the left of my L185 is a kinda squareish
cover with a knob in the middle which I thought might be a block off panel for where something should go
on some other models??? I don't know if someone can enlighten me on what it is or is there for I would appreciate it. also there is a metal toggle under the tach partially seen in the photo. Is that factory and what is it for?
I think a dirty bird has been above my tractor!
thanks
nbking
L2501HST 4X4, Rtv-x900
Jul 8, 2018
222
74
Sonora, CA
Can you open the hood and look behind, if it's wires you could trace them. When I first looked at it thought it might be on a rheostat for dash lights.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,190
171
Hardisty, Alberta
Here is a picture View attachment 63155
thanks
I don't know what the switch is for but the tractors fuses are behind that cover. Nice 185!
Arkansas Dave
Jul 12, 2021
47
17
Arkansas
The fuel tank is in front of it but I might be able to see some with a light not sure I'll look
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
298
East of Placerville Ca
I don't think the toggle is OEM. I think its probably for a set of aftermarket lights. I had 2 l245dt's and both had that fuse cover and no OEM switches, just punch outs like the black plug below the fuse cover.
Arkansas Dave
Jul 12, 2021
47
17
Arkansas
Thanks for the reply RD
3,150
There are not any toggle switches on the dash of the L185 that I own. But they did provide for some lights at the rear of the tractor and a horn in the wiring harness.
If your steering wheel can be removed easily then removing the dash and cowling is about a 5-10 minute process to see (assuming you have the factory wiring harness with disconnects near the starter.
Arkansas Dave
Jul 12, 2021
47
17
Arkansas
Thanks for the info Russell I appreciate it I'll have to see if I can trace it down and figure it out.
