dings and dent removal
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
My L3800 came to me with only 264 hours on it but it was 6 years old. The previous owner used it pretty much exclusively for hauling firewood out of forest areas. There were little things on it that I took care of right away like a broken headlight assy and one of the taillights. I'm sure they were the result of tree branches etc.
What I haven't addressed that bugs me every time I do something on the machine are the little dents and dings in the hood. I have never done body work before. Is this something I can do (do well)? I'm really not looking for a major project to start but with the weather being so crappy lately there isn't anything I can do with the tractor outside.
6,753
If they’re really little dents and dings you might consider checking with a paintless dent repair service to at least take a look at it. Most of them have mobile service and if they can do it, pretty likely having them take out the dents would be less than the materials to do a conventional hammer/dolly, spot putty, and paint job. If they can get it 100% or close enough that it doesn’t bother you, that also has the advantage of no filler in the hood. It’s pretty amazing what a good PDR tech can do with steel sheet metal.
Porcupine
L2501
Jun 15, 2021
125
153
NC
Just get out there and put some dents of your own in there.
Then the old ones won’t be so worrisome. ;)
DaveFromMi
L3901 RCR1260
Apr 14, 2021
686
754
Indiana
I have used a (clean) wetted rubber toilet plunger in the past with fairly good results for getting out dents.
Also, O'Reilly's, AutoZone sell dent removal kits that use hard plastic dent shapes and a hot glue gun to pull them out. This works OK as well. Note that this will rip off decals and labels so be careful.
If the dents are just in the hood, get a rubber mallet and tap them out from the underside.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
Thanks to all for the suggestions. re Porcupine, if they were my dents I'd be proud of them :)
I should have been more specific. They really are little dents, not something that can be 'popped' back.
I will try to find a local paintless dent repair service to see what they can do. I had even thought of pulling the hood off and taking it to an autobody place but I came to my senses. . .
lynnmor
B2601-1
May 3, 2021
1,807
1,612
Red Lion
Google dry ice dent removal, might work for you. Dry ice is available from some welding supply houses and possibly at a dairy.
Pau7220
Aug 1, 2017
785
280
Scranton, PA
I tried the heat gun / cold spray trick on a shopping cart ding.... (n)
Didn't work.
The ebay hot glue dent removal tool worked very well.
