I have a B2601 and need to decide on a grapple. I plan to use it for transporting brush and logs. I'll use it to pull blackberry bushes if it works well for that. The two models I'm considering are the Land Pride SGC0554 Claw Grapple ($1550) and the EA 55 Inch Wicked Root Rake Grapple ($2200 + $200 shipping). They are of similar shape and and size. The Land Pride is 180 lbs and has a jaw opening of 30", and the the EA is 240 lbs, with a jaw opening of 36". The widths are similar. The Land Pride has smooth tines, and the EA's tines have teeth. The larger size of the EA seems to account for most of the weight difference but may have slightly heavier steel. If I compare the price per lb, the Land Pride wins: $8.60/lb for the Land Pride and $10.00/lb for the EA. I can pick up the Land Pride from the local dealer (once they are in stock). Is there any compelling reason to go with the EA, other than the wider opening and teeth?
		 It lives at a lake now and gets used a lot but I do miss it.
