Attaching front end loader
Bigeesy
Kubota sunshine L1-265
Jun 23, 2021
New Zealand
Hi , new guy from New Zealand . Just purchased a L1-265 4cyl kubota sunshine . 1500 hours , everything original and absolutely mint . No damage , even original tyres though starting to perish a bit with age .
My question : attaching a kubota front end loader and not too many problems. I cant work out what the bolts are that attach the side support frames to the block . Haven't been able to get a manual so any help appreciated .
Cheers Lloyd
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
Well Bigeesy (Lloyd),
You are certainly fortunate to have found a vintage tractor in such good condition. I do not have much to offer yet, but here is a link with some information.
I will let you know if I find anything else.
Cheers back at you (Although when we New Englanders hear "Cheers" we think of a pub in Boston, MA
Good luck:):)
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
540
302
Mandeville Louisiana
Suggest measuring the thread diameter, pitch and depth of the threaded blind hole in the frame, add the thickness of the FEL frame, add the thickness of a lock washer and get the longest grade 12.9 metric bolt that won't bottom out. Make sure to chase and clean the threaded holes using a thread restorer. When installing consider a thread locker and torque to specifications. when finished use a white paint pen and mark horizontal or vertical lines on the bolt heads, a quick look will tell you if any fasteners are loosening. Good luck
Bigeesy
Jun 23, 2021
New Zealand
Good luck:):)
hope to float
L3450
Feb 18, 2018
474
61
Ireland
That's a beaut! Looks about the same age as mine but yours is in far better condition.
On mine, the rear part of the loader is attached to the frame using bolts with a long flat section which is slid through from the front and nuts tightened at the rear. I have no idea what these bolts are called even though I came across the name once. I'll snag a photo tomorrow when I am near the tractor
Bigeesy
Jun 23, 2021
New Zealand
Hi, figured out the attachment bolts needed are 14mm , 1.25 fine thread , high tensile . They are not readily available here so getting them made .
Frame support welded and modified (pretty simple ) so once I have the bolts the loader will be attached and then given to the hydraulic specialist to run the lines and set up the bank
Thanks for the help , another problem solved
Cheers, Lloyd.
