Do you have a WSM? You can download a free one here.
M108S WSM
I think you should take the time to rule out the most basic items. Battery cable, cable ends and cable ground to engine.
If you have a battery cable end that is like this one below, then buy a new cable if for no other reason than to eliminate it as the cause.
On page 425 of the WSM you will find the starter troubleshooting section which I have provided below.
I know you said power is not reaching the starter solenoid trigger terminal. Have you measure this with a volt meter. Sometimes tired safety switches put enough resistance into the circuit so that the starter solenoid is not triggered but a reduced voltage is actually reaching the solenoid.
