Not sure this is the right place for this question, Please redirect me if not. I have an L260 about a 1974, The steering has become Difficult ( hard to turn like no power steering) not sure if this is a gear oil problem or something much bigger, came on sudden and just trying to figure it out, thank you for any help
I have the same L260 and steering issue....which became a major problem...hard to steer, then impossible to steer, lots of issues developed quickly..Old machine and Kubota was NO help at all since steering parts (as well as the part are NLA for the L260, and other Kubota models do NOT interchange!) I tore into the steering box system, which is a nightmare in itself. I found that the upper and lower steering shaft bearings, steering shaft seals had disintegrated. Sector shaft seal was also leaking. It seems water had gotten into the steering box. I am No mechanic, so it has been a terrible experience for me! Take Lots of photos to help you put back together, when you can find the parts! I was fortunate that the ball Nut on the steering shaft was still intact and good. I do Not think you can easily repair or replace those because they do not match ANY other system I could find!
TODAY, I just found most gaskets, shims, bearings and seals. It took me a combination of internet searches, Kubota dealer Luck and
many YouTube videos (Yanmar were the best) to help me thru it!. Ready to re-assemble this coming week, God willing. Watch the videos!!!!! Get lots of good hand cleaner, towels, PB Blaster, degreaser. You will be removing instrument panel, battery tray, all wire & control connections, steering wheel, etc. The upper & lower bearings will be easy to find...
Hope you have a good place inside to do this work....save ALL nuts, bolts, etc and photos...Caution, you MUST pay attention to the re-adjustment of the front wheel steering, to help avoid any over steerage damage...There is a YouTube video that warns of the importance of this...it might be a Yanmar tractor thing...which is very similar to the Kubota L260 system.
Good Luck! I do not get on this forum much..since I am too busy fixing my tractor! I do not use any social media either.
