Replacing stock headlight bulbs with LED
shootem604
Apr 23, 2018
874
British Columbia
Is that an ordinary PAR36 lamp?...or PAR46? Messicks website shows a measured 4” diameter.
Yes but the bezel is concave and the 3" ones fit nicely inside with room for the bracket and everything so they are more flush. If you cut that bezel out you could put a 4" round LED lamp inside and maybe a little piece of angle inside to bolt the bracket to.
MSG H
L3901 HST RETIRED MIL.
Dec 20, 2020
45
20
VA
Also looking for reliable LED plug-and-play replacement bulbs for my L6060 and M9960, both of which use H4 type incandescents.
Anyone know of proven LED replacements?
B3350 is next and I think it takes common 1157s.
SDT
je1279
Dec 6, 2020
828
581
Upstate NY
SDT
These look like winners but I don't know if they will fit inside your housings or not.
https://www.amazon.com/BEAMTECH-Headlight-8000Lumens-Extremely-Conversion/dp/B06XHD78DQ
I have these on my LX2610 and they should work for your B3350.
Bpathfinder
MX5400
Apr 18, 2021
15
Louisiana
These bulbs are the same ones that I have in my 2004 Honda 450 four wheeler for 3 year. I seen they had the same base and tried them in my tractor and they worked. So I ordered another pair for it and to my surprise they work on high and low beams as they should. Hope this helps and the price isn’t bad either.
OrangeKrush
Nov 15, 2020
1,044
516
Indy
YEP! THOSE!
(I just ordered them and then saw your post...THANKS... and BTW, I apparently went thru this process last-year and then either failed to re-visit the discussion where this solution was offered...or mis-read the retailers’ offer thinking it was priced per each-lamp. The offer is actually for TWO bulbs, so not a bad offer price-wise.. My bad...)
Thanks again.
I also took as the price for one bulb..
anomad
YM2310D
Jun 10, 2021
101
55
Western North Carolina
Super bright leds is my go to as someone posted a link above. I put LEDs in my 2601 and fond the housing was optimized for the incandescent factory bulbs. It uses regular 1156 bulbs. So the lights are brighter now but more of a flood beam, which is fine for now.
If I find myself needing to tractor in the dark frequently with the days are shorter I'll need something added up on the ROPS to see over whatever is working up front.
LloydWoodke
uk
Indeed 8000k is a very blue light that harms the vision of other drivers. It would be better to look at 4300k or 5000k. This is the color temperature with the highest light output. The 4300k has the most advantages and gives the best performance in bad weather conditions (such as snow, rain, or slush). About 5000K - it's pure white. I think it's the optimal solution regarding looks and beauty to light output ratio. You can look up some options on https://lightingandsupplies.com/larson-electronics/.
dan_m
BX2380
Jul 9, 2020
198
Georgia
I don't know about tractor LED headlights but I have bought a few for my cars. I have bought 5 sets of LED bulbs. One, I manage to return did, not fit. Two, do not work right due to wrong due geometry/lack of adjustment. The other two I bought from these guys and those two sets are great in two different cars. If you want avoid a steep and costly learning curve on LED headlight bulbs, I would suggest to watch some of the videos of these guys, they know what they are talking about.
I looked into these guys for buying LED bulbs for my F150, opted not to go with them as everything they sold at the time I looked (not sure if still true today) were off-road use only. If you drive your tractor on road, something to consider.
Also, just because a LED bulb fits and is higher output, doesn't mean it's always better. Need a bulb that works well with the reflector as not all bulbs emit light in the same way. It's been a while since I did any bulb research so your mileage my vary.
bbxlr8
Mar 29, 2021
427
291
Eastern PA
I’m looking for led bulbs for the headlights on my L3130 any suggestions? Thanks
Check your spec's and the base etc and then get creative. They don't make it easy and some sellers on amazon take advantage of that. Here's what I found for 2021 model L They work great and do high/low (night & day!! :p)
PREVIOUS POST
They make it really difficult to find an interchange part number and I spent a lot of time researching it earlier this year after I got mine. It really frosts me how some people take advantage online and make up stuff for tremendous profit based on Kubota not providing an option or listing. It is all about finding the same base...
Here's what I found as a serious upgrade on a budget and it has worked beautifully for me since spring.
The Yamaha side by sides have the same base and many more options (H6 100W). Others besides this will work - pick your favorite...
I used: https://www.amazon.com/gp/product/B07SX3FGV7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
MUCH brighter and work with low/high. Note: you HAVE to pay attention and get the clocking of the base right. If you get it wrong rotate 180' I am really happy with them and it delayed adding aux lights (which I still am going to do).
Should work for all newer L's and probably others.
6,867
Parts diagram doesn't give much help. Neither does Messicks.
I'd be apt to take one out and take it to an Auto Store......see if you can find an LED match.
Flintknapper
L2350DT
May 3, 2022
1,932
2,438
Deep East Texas
That's what I ended up doing.
Even though the LED headlight bulbs were a great improvement over the OEM bulbs on my antiquated L2350DT, still not enough for any 'work'. So added an LED light bar to the ROPS.
bbxlr8
Mar 29, 2021
427
291
Eastern PA
Hi Dan,
Absolutely on target - especially for Automotive applications. My thinking here was the delta in the power draw or heat was negligible (vs the older halogens for example).
Also, higher output may not be legal for road use (not a factor for me, and could use low anyway ;) )
MORE was better for me.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
681
155
Rising Sun, MD
Replaced stock incandescent with LED. Took a bunch of measurments off the headlight lens on the tractor and made note of the bulb socket configuration. Then... I just went looking for the temperature I felt best for my tractor... Bought a pair and the fit like a glove. WITH ONE HICCUP! The wiring polarity was backwards!
I switched leads in the wiring harness before the "Y" that went to each bulb. Worked like a charm!
Seeing as how I modified OEM wiring configuration... I made a note in two places for those who will follow me... One in the WSM and the other under the hood with a sharpie...
bbxlr8
Mar 29, 2021
427
291
Eastern PA
Hi Butch - FWIW This happened to me also and I was able to rotate the bulb 180' to get it to work
